2017-02-19, 11:58
(2017-02-19, 06:09)Papo1980205 Wrote: [ -> ]Where can I get latest version of skin for krypton.TIA
from beta repository. check first posting.
@Topic: any suggestion on how to disable the background picture permanently?
(2017-02-15, 19:41)cookem Wrote: [ -> ]seems like a kodi bug then that it is not following the advancedsettings.xml to hide empty series (i have this set to true)
<hideemptyseries>false</hideemptyseries> <!-- set to "true" to hide empty series in the video library and prevent empty series from being removed during a library cleanup. -->
(2017-02-15, 20:59)Simograndi Wrote: [ -> ]I've just tried using default English language, but it still happens. Some cache issue?
(2017-02-15, 20:59)Simograndi Wrote: [ -> ]I know in fact this is strange. I have that option enabled BTW, and with different LY is working
(2017-02-15, 22:44)teedo42 Wrote: [ -> ]1. I am now unable to access extended info period. The screen doesn't open, an error message pops up. If I access the regular Kodi cast, it no longer opens. I am now at version 3.7.45.
2. In the media library, I am unable to change the view on some movies. I cant get the fanart to display, just landscape art. I have the option set to prefer fanart. Some will change but most wont.
(2017-02-16, 00:37)jasn Wrote: [ -> ]This may be a key mapping problem for MS remotes but the lack of the "back" tab at the top of the Music Category Subfolders will not allow you to return to the main menu.
1. From Music the Categories appear, including a "back" tab.
2. Choose a Category along the upper part of the screen: say Artist;
3. Go to the top of the Artist menu and select the "back" tab of three dots;
4. The menu kicks you back into the Category list, not the Main Menu, but you cannot get out of this list by continuing to press a remote back button. You must use the "esc" key on a keyboard. There is no "Back" tab to press either.
If there was a "back" tab at the top of the Category list in Step 3 above you could choose that to return to the Main Menu, but one does not exist. Also, I do not see this problem in Movies.
(2017-02-16, 01:20)oattes Wrote: [ -> ]It's definitely enabled, but the option does not appear in the OSD/Music settings.
(2017-02-16, 21:43)Saed Wrote: [ -> ]The OSD logos on the playback of a movie sent from the main menu do not play correctly when you have half a view (for example 57%)
However if you play it from the movies section, you do not have this problem.
(2017-02-16, 22:20)snarfo Wrote: [ -> ]Is there way to enable a widget with Recent TV Channels in the PVR section? I found that handy since I generally only watch a handful of channels anyway and it was convenient to have them on the home screen in a widget instead of having to go into the channel guide and find them there.
(2017-02-17, 03:16)onesane Wrote: [ -> ]Absolutely love the skin Marcel! I've been using and customizing the beta version for krypton obsessively the past week or so. Wonder if you could help me troubleshoot a problem I'm having...
Windowed trailers on the media info page are not working properly for me whether it's set to autoplay or normal. The movie poster goes away and the video box appears as it would to begin windowed play, but it's just a black screen. After a few seconds, the loading icon appears briefly just before the video switches to full screen mode. But in this full screen mode, the video is still windowed-sized and in the position it would've been. Like a tiny window in a huge black background.
The trailer video itself plays normally, audio/visual-wise. Although tiny and to the right, like I said. If I press back, it returns to the library view - just like it would had it played in normal full screen mode.
Any ideas on how to fix this? I am on the latest beta release, by the way (the one that updated yesterday). And this problem was happening before that most recent update, if that's important.
(2017-02-17, 14:12)MediaGuy Wrote: [ -> ]Settings -> Skin Settings -> Configure shortcuts -> Edit menu shortcuts
That screens shows Movies at the top of the list but nothing shows in the home screen. (Movies is enabled)
How can I show the movie menu entry?
I can display Videos but to access them I have to go through several menu's everytime. No movie info is given and DVD images/folders don't work; only single file movies work.
(2017-02-17, 14:21){{INX}} Wrote: [ -> ]Hi Marcelveldt, I have been using your skin for a long time and love it but since moving to Krypton I have an issue that keeps happening.
When I go to skin settings, most of the time the menu options are all just empty grey boxes but sometimes after a restart they work again.
I have also noticed that although the boxes have no text I can remember what some buttons do and for example, I open the edit menu shortcut screen to carry on what I am working on but when I try to make a smart shortcut to Emby folders all it gives me is a button that says '>' instead of 'Smart Shortcut'.. this is fixed once I restart and the menus all show again.
I have checked and all addons are up to date as well as Kodi Stable.
(2017-02-17, 14:21){{INX}} Wrote: [ -> ]Another thing, is it possible to have a sub sub menu option to allow me to tidy up the main screen?
(2017-02-17, 14:21){{INX}} Wrote: [ -> ]Is it possible to have the 5 day weather across the top of the home screen rather than a menu option?
