twotone8 Wrote:what's the best (and most affordable) newsgroup host provider? what are you guys using? do any of the free ones out there have the nzb functionality needed to run this plugin?
I use "Supernews"... $12/month (800 day retention)
Astraweb ($10/month or $96/year, 1000 days retension) + NZBMatrix ($10 one-time) + SABnzbd + SickBeard + CouchPotato is friggin' brilliant
This script is absolutely brilliant. Thanks a lot! One side note... with nzb.su the script is failing with an error. Does this mean I configured the source incorrectly, or is it a bug?
Bram77 Wrote:This script is absolutely brilliant. Thanks a lot! One side note... with nzb.su the script is failing with an error. Does this mean I configured the source incorrectly, or is it a bug?
Yes, nzb.su works for me. Check the RSS link on the bottom of the page for the correct info....
If you just want to get your feet wet and don't plan on doing a ton of stuff. Astraweb. 180GB for $25.
Average hour long TV show in SD is 700MB.
(180 GB) / (700 MB) = 263.314286
That's an entire season of 10 - hour long shows (averaging 26 episodes per season).
Twice that of half hour shows.
180GB usually lasts me 4-5 months with everything I use it for. That's $15-25 cheaper than the monthly rate.
This is by far the plugin I use the most. Keep up the good work! Skål.
I have downloaded and installed plugin.video.nzbs-0.0.6.zip and SabnZab0.6.0Beta 4. I have NZB.su account so i setup those details in the plugin.
Now I can see all categories form NZB.su like Moves HD, SD other etc...
But When I click HD or anything from the category I am getting script error. ( Here is the XBMC log file
http://pastebin.com/J9QULRfM )
From prerequisites , I am not sure how to set these two
1.SABnzbd has to have some default post processing like +delete
2.The incomplete folder of SABnzbd has to be rw by XBMC
Could you please let me know how to set those . For your reference I am using windows 7 x64 bit version system.
itssuresh dont know really. you should just have numbers and letters in the codes no ampersands etc...
Popeye Wrote:@itssuresh dont know really. you should just have numbers and letters in the codes no ampersands etc...
Can you please let me know how to set these in windows
itssuresh Wrote:Can you please let me know how to set these in windows
1. If you just have installed SABnzbd the default post processing is set to +delete. You should read
the manual.
2. rw = read write. If SABnzbd is running as the same user (e.g. you start it manually) as your XBMC, then XBMC can write to the incomplete folder.
This looks great. Just waiting for smb location support for the incomplete folder to try this out.
ghostelement Wrote:This looks great. Just waiting for smb location support for the incomplete folder to try this out.
You have to map/mount the drive.
Popeye Wrote:You have to map/mount the drive.
No plans to build in SMB folder browsing? I really don't want to have to map a drive just for this.
