Pretty new to Kodi so sorry if this is something simple. Trying to get OzWeather working for my area. In the OzWeather settings, I'm trying to 'Change Suburb 1' but get an error on every postcode I enter. Log below.
15:34:18 878.488220 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
15:34:18 878.488403 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['default.py', 'Location1']
15:34:39 900.413696 T:1581937568 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: name 'middle' is not defined
File "/storage/.kodi/addons/weather.ozweather/default.py", line 915, in <module>
log("Error - middle: " + str(middle) + " skimmed " + str(skimmed))
NameError: name 'middle' is not defined
15:36:57 1038.304810 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
15:36:57 1038.305054 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['default.py', 'Location1']
15:37:09 1050.197998 T:1581937568 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xe2 in position 89323: ordinal not in range(128)
File "/storage/.kodi/addons/weather.ozweather/default.py", line 881, in <module>
locationName = common.parseDOM(resultPage, "h1", attrs = { "class": "local" })
File "/storage/.kodi/addons/script.module.parsedom/lib/CommonFunctions.py", line 299, in parseDOM
temp = _getDOMContent(item, name, match, ret).strip()
File "/storage/.kodi/addons/script.module.parsedom/lib/CommonFunctions.py", line 162, in _getDOMContent
end = html.find(endstr, start)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 89323: ordinal not in range(128)
15:37:21 1062.119507 T:1664205728 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
15:37:21 1062.119995 T:1664205728 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['/storage/.kodi/addons/weather.ozweather/default.py', '1']
15:37:28 1069.182251 T:1548383136 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png
15:37:30 1071.245728 T:1664205728 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Exiting ....
15:41:52 1332.974731 T:1548383136 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
15:41:52 1332.974976 T:1548383136 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['default.py', 'Location1']
15:41:54 1335.072510 T:1548383136 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Exiting ....
15:41:56 1336.574585 T:1548383136 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
15:41:56 1336.574829 T:1548383136 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['default.py', 'Location1']
15:42:07 1347.737915 T:1548383136 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
15:45:19 1540.265503 T:1664205728 ERROR: Texture manager unable to load image from memory
15:50:16 1836.731079 T:1963229184 ERROR: Previous line repeats 1 times.
15:50:16 1836.731323 T:1963229184 ERROR: Unable to activate the previous window
15:50:16 1837.044922 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
15:50:16 1837.056885 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['/storage/.kodi/addons/weather.ozweather/default.py', '1']
15:50:24 1844.501953 T:1581937568 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Exiting ....
15:52:52 1992.460083 T:1664205728 ERROR: Texture manager unable to load image from memory
15:57:02 2242.450195 T:1774973856 ERROR: Previous line repeats 1 times.
15:57:02 2242.450195 T:1774973856 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
15:57:02 2242.450439 T:1774973856 ERROR: CCurlFile::Open failed with code 0 for
http://feeds.openelec.tv/news
16:20:24 3644.951416 T:1664205728 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Starting ...
16:20:24 3644.951660 T:1664205728 NOTICE: ### Oz Weather - 0.8.1 ### Called as: ['/storage/.kodi/addons/weather.ozweather/default.py', '1']
16:20:28 3649.261719 T:1664205728 NOTICE: ### Oz Weather - 0.8.1 ### Oz Weather (Author: Bossanova808) Exiting ....
Am I missing something?
Cheers,
Josh
