wacko37 Well, I very reluctantly made a file for the monstrosity that is Estuary (which is 1080p - so would be easy to work from). But I will only support the standard skin and whatever other skin(s) I use (Confluence, at the moment). I consider the addon my bit, others can deal with their own skin wishes. It's really not hard to do a MyWeather.xml - even if you were completely new to Kodi skinning you could probably do most of it in an evening. So I shall leave that as 'an exercise for the reader' - happy to help with specific bits if you get stuck, but not gonna spend my time doing it from scratch (and forever more updating it) - given I will never use it.
I totally understand and thankyou for taking the time to respond. Cheers
bossanova808 Firstly big thanks for giving me the push i needed to modify this for myself, wasn't that hard after all
Well i kind of cheated as i used the skin "Aeon MQ5 (Gotham era)" by @
uksa007 which worked in MQ8 but the resolution was for 720p. So big thanks to @
uksa007 also!
I have also made some changes like the background, font and font colour, which means i also had to modify the font.xml for MQ8.
I can provide the files needed if anyone is interested, or if @
bossanova808 want to add them to the addon wiki.
wacko37 Good job! You can actually go ahead and add them to the wiki too - that's the point of a wiki, it's a community editable resource. It's even easier than making the skin file!
(2019-03-06, 02:39)wacko37 Wrote: [ -> ]@bossanova808 Firstly big thanks for giving me the push i needed to modify this for myself, wasn't that hard after all
Well i kind of cheated as i used the skin "Aeon MQ5 (Gotham era)" by @uksa007 which worked in MQ8 but the resolution was for 720p. So big thanks to @uksa007 also!
I can provide the files needed if anyone is interested, or if @bossanova808 want to add them to the addon wiki.
I would very much like the files please.
I am using OzWeather with AeonMQ 8 but have a horrible blue background that I do not know how to change.
Thank you
bossanova808 ,
Just a quick note, have added a place holder entry about my skins integration of your weather script to your wiki. Now realise that my wiki page is horribly out of date, so after I have cleaned things up there, will add some pictures to go along with the wiki text.
Wyrm (AppTV)
benrita I will be adding everything to the wiki today with readme.txt instructions.
(2019-03-06, 09:30)wacko37 Wrote: [ -> ]@benrita I will be adding everything to the wiki today with readme.txt instructions.
Thank you, is that the OzWeather wiki ?
wacko37 I added your link to the files to the wiki...
