(2019-12-28, 08:54)bossanova808 Wrote: [ -> ]In the meantime, you could manually take the background images and convert them to RGB, re-save them, and disable the periodic updating of background images. Someone has done that in the past if you search this thread (which is why the 'don't refresh backgrounds' feature was added..
Hi, and thanks for your reply and time while you're on holiday (and sorry I didn't know you actually replied, as I was expecting email notifications on replies like other forums). OK, upon seeing your reply, I thought this would work, as logically it should, but nothing has changed, which is perplexing.
I managed to grab the images, converted them to RGB, and found the appropriate folder
/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata/addon_data/weather.ozweather/radarbackgrounds, where it turned out all images were there, but only the legend image was RGB. So I converted those to RGB, turned off the periodic updating, restarted Kodi, but still no background to the radar. Restarted Kodi a couple of times, and even rebooted Android, but still no go.
So, just in case it made a difference, I replaced the images with those I had downloaded and converted, but still no change. Then upon finding another folder
/userdata/addondata/weatherozweather/currentloop/ which had the legend image, I copied the others there as well, to no effect. I even tried having multiple files with different names in both those folders, because I couldn't help notice that the legend image in the folders was not named
IDR.legend.0.png as from their site, but i
dx.legend.0.png. So I made multiple copies of each with varying combinations of uppercase/lowercase IDR/idx, but still no background images appear in the loop.
Also I should add that while that legend image was there, it doesn't actually show up, just the copyright warning, rainfall overlay and counter. Anyway, no rush, thanks for your time, and enjoy your holiday. Cheers
