2014-03-12, 17:02
Thanks for all the comments!
@iAMl3dgend : Thanks! and the coloured tiles will hopefully be added into the next update
@ADHDMedia : I sometimes find this error when playing some games on Xbox, and then signing in to XBMC. For some reason the gamertag script cannot get info for certain games. Also it is case sensitive when entering your gamertag so make sure that you add any upper/lower case letters on there because the script could fail if it's not right. and Thanks!
@ADHDMedia : Thanks!
@jamescrow : The update section should only pop up once on your first time using the skin or if you toggle the setting in skinsettings (Uncheck to run setup on next boot). Also the update section just toggles all the skin settings to how i always keep mine and it adds to the experience. So if you play around with the settings and something goes wrong then you can toggle the setting "Uncheck to run setup on next boot" and then they will all go back to normal the next time you start up.
@iAMl3dgend : I am just uploading the skin now so it should be online in an hour or so
I am just uploading the skin now so it should be online in an hour or so.
There have been a lot of things added to the skin but the Xbox Video section still needs a lot of work. At the moment the buttons direct you to trakt.tv and the search button searches youtube. I will shortly be adding updating advertisements with latest movies/tv shows ect.
To get to your video library you can now go to the movies section to the right of the dashboard, then go to my collection.
Also the textures really need to be cleaned up because they are now at 400mb. But i will give them a good clean up in the next update.
