So I get advert.py and bing.py errors when I turn on the options in settings to show games and bing on the dashboard. Any suggestions? Also snap.py when I go to "home" from the charms bar. And it shows an exclamation in the big tile on dashboard after that.
Oh ya - how do we change the two tiles on the dashboard?
ADHDMedia : Do you have the assistance folder extracted in the root of you hard drive ? It should be located at "C:\Assistance\" As this is where bing stores the images and there are some other scripts in there.
If you don't have it installed then it can be downloaded from the first page.
And to change the two tiles on the dashboard you just go to skin settings, the custom section (on the left) and then at the bottom of the list there are 2 options : tile 1 & tile 2.
Ok cool. And I extracted those files to my C drive directly, without the Assistance folder in the file structure. Fixed! Thanks buddy.
Hmm… adverts.py still gives me an error, but bing.py works. Wonder why?
Also... When I install the update package into the 720p folder, my whole dashboard disappears. What am I doing wrong there?
On another note, there's a few issues with the new views in the advanced launcher section. You cant arrow up to info on the new views and there's also some overlay of the labels. Check it out when you can.
Toyota the skin is great of course but you already knew that
The new pins on the homescreen are great
But I actually meant more like this
See the screenshot in the link! see the magenta tiles in the pin section on the homescreen
https://onedrive.live.com/redir?resid=D7...oto%2c.png
ADHDMedia : Yeah there was a spelling mistake in the update, It should all be working fine now and the download link has just been updated on page 1.
Ahh i didn't notice that problem i will create a fix for that now and will upload a little update shortly.
grote345 : Thanks
! and ohh rite i get what you mean now, I will add this feature in to the next release.
Still have a disappearing dashboard with the update package installed. In re running the setup now to see if that fixes it.
Oh and thanks for the view fixes [THUMBS UP SIGN]
Thank you sir! And I think I fixed the script errors, it was Smart Screen not wanting to let the apps run.
Toyota thanks for the views fix and thanks for your comment thanks for understanding me now If you do it like this with the pins I mean you don't need the real pins/custom pins option anymore
You will only have a pins section understand what I mean ?
Because you have both in the pins section on the home screen less textures this way
Toyota by the way I like the video you have uploaded on youtube about the XboxOneOs on the pc mean the latest video off course I did subscribe to youre channel
ADHDMedia I use Frodo 12.3 and I don't have any problems everything works like charm
if you extract the skin to c:\users \ youreusername \ appdata \ roaming \ xbmc \ addons and the skin is extracted, try to delete first the includes_home.xml and the skinsettings.xml first
and then extra the updated includes_home.xml and the skinsettings.xml
It worked for me doing it like this and if that does not work I think je profile in xbmc is corrupt I had the same use before and after creating a new user profile in xbmc everything was working great again.
That last update fixed the dashboard missing all the tiles, but now I'm having a huge issue where everything on the dashboard lags to shit. I tried uninstalling/reinstalling the skin as well as XBMC completely. I'm now trying to create a new user account and see if that fixes it.
Nope. Don't know what I did this time but it just doesn't seem to wanna work for me anymore lol
I'm sure it was on my end tho, don't worry about it Toyota. I'll get it worked out.
Still trying to fix it [PENSIVE FACE]
