@anonomys209: Yeah I forgot to tell you that you will just get a black screen as XBMC can't get fanarts for pin tiles, this is just the way that XBMC works and cannot be changed from the skin.
I might be able to add a fanart multiimage that will pull fanarts fro everything in your library, but then it wouldn't look right when launching a game a completely different splash screen would show.
@anonomys209: Hmmm it's centered alright on my TV and that's 1080p. I will take a look in to it when I get home.
Yeah I have forgot to add back in this feature after editing the library sections, I will include this feature again in the next update.
bakito : Yeah I think that it might do, in the next update a lot of the dependencies will be getting removed and XBMC will get them from the store if you don't have them.
But it shouldn't do anything to your launcher configuration as all it does is update the advanced launcher plugin.
Nataniel4 : Nope this feature has not been added yet. I completely forgot about it as I have been focusing on adding in the friends section and fixing all of the problems.
I will include the splash option in the next update.
raven_rvz01 : Hmmm it's all working fine over here. Do you have the latest Xbox One drivers installed ? And do you have 2 controllers plugged in ? The Xbox One controller is laid out a little differently than the Xbox 360 controller. The menu button will open up the context menu. Back will open up shutdown menu.And Y opens up the context menu.
The categories bug is because A is mapped to open game options in the advanced launcher plugin. I will fix this when I get home.
The YouTube errors won't be anything to do with the skin unless on setup it wasn't installed correctly.
Have you tried re-installing the YouTube plugin from the store ?
If you send me a copy of your log then I might be able to find out the problem.
anonomys209 : If you just go in to your keyboard xml and find the I button, copy the command linked to that button. Open up your keymap xml for the 360 controller and find the button that says "FullScreen". Replace that with the command from the keyboard xml.
Sorry I can't explain it very well as I am not at home at the moment, but when I get back then I can upload a keymap with the changes made if you want.
Nataniel4 : Nope I haven't gotten around to adding in this feature yet as I have been fixing problems and working on the friends section. I will include the splash screen in the next update.
Thanks man!
