(2016-09-22, 07:23)Statikk Wrote: [ -> ]There is a new build. I won't have a chance to test tonight though.
Sept 22 EXE
Sept 22 PDB
So far, this build is working well for me - 3D ISOs and MKVs are playing correctly. I haven't noticed anything misbehaving - awesome work by afedchin!
I also concur. Everything seems to be working - HD audio, Dolby digital plus, 3d mkv and isos. Thanks afedchin!
any advice on which will i get?
zidoo x9s or himedia q5 pro?
must passthrough atmos and x flawlessly
must be good in upscaling to 4k or 1080p
picture quality must be great
no audio sync problem
no lags
supports hdr
fast and responsive
Asking in a htpc thread, I would definitely go with a Skylake NUC!
(2016-09-22, 12:27)bongchillog Wrote: [ -> ]any advice on which will i get?
no lags
supports hdr
fast and responsive
3D ISO is still not working for me with this latest build on a Philips Gioco passive 3D monitor with nVidia 960. Audio is there, but video still not showing. 3D MKV works on the same monitor. Will test this build on the LG TV later on.
Edit: on the main 3D set with Intel hardware everything seems to be OK now. Every kind of 3D container is displayed correct as far as I can see and test.
(2016-09-22, 11:54)woronczak Wrote: [ -> ]I also concur. Everything seems to be working - HD audio, Dolby digital plus, 3d mkv and isos. Thanks afedchin!
I have a D34010WYK NUC and as above, all seems to be well.
AWESOME! thanks for the update - greatly appreciated
mac mini - latest model, win10, intel 5100 gpu.
Unfortunately with the 9/22 build I still have the chapter skip/ff/rw issue with MVC MKVs that contain DolbyTrueHD audio.
Tested with Everest (which had the issue before) and also Warcraft. I'm running a DN2820 NUC.
Sweet!
I will install it and test it over the weekend.
Thanks a lot afedchin for your work
(2016-09-22, 13:08)bollstedt Wrote: [ -> ]Asking in a htpc thread, I would definitely go with a Skylake NUC!
no lags
supports hdr
fast and responsive
Interested in a Skylake NUC. I need it to be silent but my concern is the fan for cooling the CPU or is there a NUC with very low noise? any recommendations of specific models of NUC.
Thanks,
I will try 22 Sep build today with Intel NUC5I5RYK, latest Intel driver (15.40.28.4501) and Optoma GT1080 projector.I will send my feedback later today
Hey all,
first of a BIG thanks for creating this build. I got a new 3D capable projector and I really had a hard time to get it working in Kodi (just with external tools and not reliable). Now I stumbled over your MVC fork and I love it (currently using the June build). All 3D I tested is working perfectly fine and out of the box! You made me happy
I got a question regarding skins. If I would use a skin which is Krypton compatible would it work with this MVC version or would I miss like the 3D options from within a movie?
Even though I really like the clean and easy approach of the new Krypton standard skin, I am missing the Aeon MQ feeling when it comes to looking at the Video section.
Also a question which most likely noone knows the answer but I try anyhow
. I got a Intel BB NUC5i3RYH Rock Canyon i3 with Win10 64bit connected to a Marantz SR6010 receiver and since the NUC just has HDMI 1.4 I now tried to use a adapter from Display Port to HDMI which is able to support all this HDR, 4k whatever highspeed. This is working well beside when I start a 3D movie with this MVC version. It looks like the receiver does not get any video signal anymore once the 3D movie is started and I have to use the task manager to kill Kodi. Using just the HDMI 1.4 NUC output the 3D movie is working fine. Any thoughts?
However again really happy this NUC specific release exists. Many thanks to the developers!
NoTechi
(2016-09-23, 12:55)NoTechi Wrote: [ -> ][cut]
Also a question which most likely noone knows the answer but I try anyhow . I got a Intel BB NUC5i3RYH Rock Canyon i3 with Win10 64bit connected to a Marantz SR6010 receiver and since the NUC just has HDMI 1.4 I now tried to use a adapter from Display Port to HDMI which is able to support all this HDR, 4k whatever highspeed. This is working well beside when I start a 3D movie with this MVC version. It looks like the receiver does not get any video signal anymore once the 3D movie is started and I have to use the task manager to kill Kodi. Using just the HDMI 1.4 NUC output the 3D movie is working fine. Any thoughts?
NoTechi
You do not say what DP to HDMI 2.x convertor you use, but if it is the one from
Club 3D then they say this is compatible with Intel Skylake and newer (6th generation core series). Maybe there is where it goes wrong?
