(2016-09-23, 02:20)woronczak Wrote: [ -> ] (2016-09-22, 11:54)woronczak Wrote: [ -> ]I also concur. Everything seems to be working - HD audio, Dolby digital plus, 3d mkv and isos. Thanks afedchin!
I have a D34010WYK NUC and as above, all seems to be well.
Same here, working great w/same NUC, both 3D MVC MKV's and 3D ISO's. And, as I mentioned before, DD+ and TrueHD/ATMOS bitstreaming perfectly as well.
What's not working?
3D auto flipeyes for right-eye first titles Working (if headers are correct)
- 3D mode auto-engage for SBS and TAB titles
Also Windows needs to be set to 1080p for the 3D to work, so if you're setting it to 4k@xxhz then it won't work.
hdmkv What's not working?
- 3D auto flipeyes for right-eye first titles.
i have tested a few titles rio promethus and they work for me.
I have a NUC5I5RYK,Win 10 64-bit with latest Intel driver (15.40.28.4501) and Kodi 22 Sep release.
Just finished a full 3d movie (x-men apocalypse) complete blu ray. Unfortunately, i faced some hang issues at the start of movie, but clicking rewind button solved this issue. Also, i faced a flip eyes issue (3D breakage) during the movie 1 time an solved by re sync the projector signal.
Overall i feel that the picture quality in 30th June build is better than 22 Sep build.
(2016-09-23, 23:31)bdreams Wrote: [ -> ]@hdmkv What's not working?
Thanks... could be my hurried-up testing; will try again this evening.
(2016-09-23, 08:17)Statikk Wrote: [ -> ]Unfortunately with the 9/22 build I still have the chapter skip/ff/rw issue with MVC MKVs that contain DolbyTrueHD audio. Tested with Everest (which had the issue before) and also Warcraft. I'm running a DN2820 NUC.
Can anyone else reproduce this issue?
My bad. 3D auto flip-eyes is indeed working with this build, at least with two random right-eye first titles I tested with ('Peanuts' movie & 'Edge of Tomorrow').
(2016-09-25, 00:01)hdmkv Wrote: [ -> ]My bad. 3D auto flip-eyes is indeed working with this build, at least with two random right-eye first titles I tested with ('Peanuts' movie & 'Edge of Tomorrow').
Did you manually set the REF in the player's settings previously? If so, Kodi would have remembered that.
Not sure I follow you... REF? With 9/19 build, flip-eyes didn't happen automatically w/right-eye first titles. Working fine it appears with 9/22 build.
(2016-09-25, 03:14)hdmkv Wrote: [ -> ]Not sure I follow you... REF? With 9/19 build, flip-eyes didn't happen automatically w/right-eye first titles. Working fine it appears with 9/22 build.
Right
Eye
First.
And the question was did you previously manually flip the eyes while watching a REF movie with the player controls.
If you did, Kodi will remember that you have manually made that change and will then flip eyes "automatically".
Also, how are you denoting which eye is first? Are you editing the header of the MKV?
99% of my 3D movies are ISO's, but in any case, 'Peanuts' movie & 'Edge of Tomorrow' which I mentioned do auto-flipeyes now. Will try a few more to verify.
For some reason with this update audio passthrough stopped working (DTS, AC3, DTS-HD etc.). The June build had other issues but passthrough worked. The setup is exactly the same -
I tried disabling and enabling and in both the cases it seems Kodi does the decoding as Denon shows PCM and multi-channel. Re-installed Jarvis build in a temporary location and passthrough works there so not something on the PC. By the way, 3D seemed to work great but I didn't spend much time there due to this issue.
Anything else to look in particular before I try with a clean setup? Running W10 on i5-6500 (integrated video) with Gigabyte z170n motherboard. Thanks.
I'd try uninstalling w/removing profile (after backup), and doing a clean install of new build.
