(2016-04-29, 14:31)hdmkv Wrote: [ -> ] (2016-04-29, 12:14)DeejayT Wrote: [ -> ]Nuc6i3 work very good with 3d. No problems.
Thanks, added to spreadsheet in post #1. Can you reply which graphics/audio driver combo you're using?
Finding it odd that you're not reporting any issues w/NUC6i3SYH or NUC6i3SYK, while @movie78 got blurriness w/two different 6i5 NUC's (NUC6i5SYH or NUC6i5SYK). Intel HD Graphics 520 vs. 540. And, I believe @dukester's Skylake has Intel HD Graphics 530. Again, odd only 540 would have issues.
Thanks for all members that helping with issue,
this mean the I5 skylake will do blur image , you recommended to take I3 skylake nuc ?
what do you mean " For Cinavia, just leave AnyDVD HD running in the background. It'll take care of it. "
you could please explain me how to do that ?
Movie78 : this nuc "D34010WYK " that you have it run 3D iso and all media in win10 64bit ?
thanks for all .
(2016-04-29, 14:58)Neighbour Wrote: [ -> ] (2016-04-29, 14:31)hdmkv Wrote: [ -> ] (2016-04-29, 12:14)DeejayT Wrote: [ -> ]Nuc6i3 work very good with 3d. No problems.
what do you mean " For Cinavia, just leave AnyDVD HD running in the background. It'll take care of it. " You don't need that..
you could please explain me how to do that ? Use AnyDVD to rip your Disc that will remove the protection (Cinavia)
Movie78 : this nuc "D34010WYK " that you have it run 3D iso and all media in win10 64bit ? YES
thanks for all .
Forget everything about PowerDVD and you don't need AnyDVD running in the background, just download Kodi @
afedchin 3D MVC build and follow the instructions on the first page.
Done.
Re: Cinavia and AnyDVD HD,
see here. If you have latter running in the background, it should disable former on the fly, at least w/these builds of PowerDVD...
Quote:- New: PowerDVD 12 build 5612 is now supported by AnyDVD's unique Cinavia fix
- New: PowerDVD 13 build 5423 is now supported by AnyDVD's unique Cinavia fix
Re: Skylake reports, here's what we have...
- NUC6i3SYH / NUC6i3SYK i5-6100U w/Intel HD Graphics 520 = @
DeejayT, no issues; @
movie78, blurriness
- NUC6i5SYH / NUC6i5SYK i5-6260U w/Intel Iris Graphics 540 = No reports I've seen
- Intel Core i3-6300 w/Intel HD Graphics 530 = @
dukester reported no issues
Quote:Finding it odd that you're not reporting any issues w/NUC6i3SYH or NUC6i3SYK, while @movie78 got blurriness w/two different 6i5 NUC's (NUC6i5SYH or NUC6i5SYK).
This was my current setup when i had the i3 Skylake NUC
BENQ W1070 PJ
YAMAHA RX-A3050
Intel Nuc NUC6i3SYH
Tested Media A Turtle Tale 3D
First Unit -Did all the Video setting that @
afedchin requested and had
BLURRINESS
Second Unit -Same settings same issue.
Got the Intel NUC DN2820 and I am not seeing any
BLURRINESS
(2016-04-29, 15:44)movie78 Wrote: [ -> ]Quote:Finding it odd that you're not reporting any issues w/NUC6i3SYH or NUC6i3SYK, while @movie78 got blurriness w/two different 6i5 NUC's (NUC6i5SYH or NUC6i5SYK).
BENQ W1070 PJ
YAMAHA RX-A3050
Intel Nuc NUC6i3SYH
First Unit -Did all the Video setting that @afedchin requested and had BLURRINESS
Got the Intel NUC DN2820 and I am not seeing any BLURRINESS
My neighbor has a gen 6 Nuc and has no issues with it.
BENQ W1070 PJ
YAMAHA RX-A3050
Intel Nuc NUC6i3SYH
Are you using screen size scaling anywhere? That can really mess up a 3D picture.
(2016-04-29, 15:27)hdmkv Wrote: [ -> ]Re: Cinavia and AnyDVD HD, see here. If you have latter running in the background, it should disable former on the fly, at least w/these builds of PowerDVD...
- NUC6i3SYH / NUC6i3SYK i5-6100U w/Intel HD Graphics 520 = @DeejayT, no issues; @movie78, blurriness
- Intel Core i3-6300 w/Intel HD Graphics 530 = @dukester reported no issues
Thanks , if I use powerdvd 15/16 ?
and you mean running - only download the AnyDVD software and click on it and open it and minimize it and play on powerdvd the iso 3D ?
thanks.
(2016-04-29, 18:24)opeters Wrote: [ -> ] (2016-04-29, 15:44)movie78 Wrote: [ -> ]Quote:Finding it odd that you're not reporting any issues w/NUC6i3SYH or NUC6i3SYK, while @movie78 got blurriness w/two different 6i5 NUC's (NUC6i5SYH or NUC6i5SYK).
BENQ W1070 PJ
YAMAHA RX-A3050
Intel Nuc NUC6i3SYH
He has gen 6 of I3 or I5 ?
(2016-04-29, 15:24)movie78 Wrote: [ -> ] (2016-04-29, 14:58)Neighbour Wrote: [ -> ] (2016-04-29, 14:31)hdmkv Wrote: [ -> ]Thanks, added to spreadsheet in post #1. Can you reply which graphics/audio driver combo you're using?
thanks for all .
Forget everything about PowerDVD and you don't need AnyDVD running in the background, just download Kodi @afedchin 3D MVC build and follow the instructions on the first page.
Done.
Thanks,
from where you buy D34010WYK , I try to find that on amazon.com and not give any result .
If I use Powerdvd 15 /16 ULTRA I don't need to use AnyDVD on background to get a way of CINAVIA ?
(2016-04-29, 19:18)Neighbour Wrote: [ -> ]Thanks , if I use powerdvd 15/16 ?
thanks.
So, what this thread is about and what you're asking are not related. I'm understanding you want to use PowerDVD as an external player w/Kodi because you want BD menus. And, not the integrated MVC playback builds w/o menus we're talking about in this thread...
In this case, yes, if you leave AnyDVD running in the background, it disables/bypasses Cinavia on the fly. At least for the PDVD builds I mentioned before. Just checked
RedFox's forum and PDVD 16 w/Cinavia bypass is expected to be supported in the next version.
(2016-04-29, 19:24)hdmkv Wrote: [ -> ] (2016-04-29, 19:18)Neighbour Wrote: [ -> ]Thanks , if I use powerdvd 15/16 ?
thanks.
In this case, yes, if you leave AnyDVD running in the background, it disables/bypasses Cinavia on the fly. At least for the PDVD builds I mentioned before. Just checked RedFox's forum and PDVD 16 w/Cinavia bypass is expected to be supported in the next version.
thanks,
about this "integrated MVC playback " it show real menus of Blueray disk like POWERDVD ?
And you can confirm that product :
http://www.amazon.com/Intel-NUC-NUC6i3SY...018NSAPIM/
support 3D ISO and Menus without black screen or blurring 3D or audio lip sync ?
Thanks .
(2016-04-29, 19:52)Neighbour Wrote: [ -> ] (2016-04-29, 19:24)hdmkv Wrote: [ -> ] (2016-04-29, 19:18)Neighbour Wrote: [ -> ]Thanks , if I use powerdvd 15/16 ?
thanks.
thanks,
And you can confirm that product : http://www.amazon.com/Intel-NUC-NUC6i3SY...018NSAPIM/
Thanks .
yes that device supports 3D, no Kodi does not support menus currently.
(2016-04-29, 20:02)dukester Wrote: [ -> ] (2016-04-29, 19:52)Neighbour Wrote: [ -> ] (2016-04-29, 19:24)hdmkv Wrote: [ -> ]So, what this thread is about and what you're asking are not related. I'm understanding you want to use PowerDVD as an external player w/Kodi because you want BD menus. And, not the integrated MVC playback builds w/o menus we're talking about in this thread...
thanks,
Thanks .
thanks,
support I know but with bug like blurring- movie78 is talking about that because of that I am very confused what to take that work well without any issues.
i spent the majority of the day trying to build Kodi from afedchins latest mvc source.. im giving up for today, i got as far as only 4 build errors but it still wont run. sticking with the 0420 build for now i guess
thanks.
thanks,
about this "integrated MVC playback " it show real menus of Blueray disk like POWERDVD ? YES
support 3D ISO and Menus without black screen or blurring 3D or audio lip sync ? Yes / So far All 3D menu i have try doesn't work / No Lip-Sync error
Thanks .
For some decrypted Blu-ray
If you have prime, just return it, if it doesn't work..
