(2016-11-19, 22:22)fmedrano1977 Wrote: [ -> ]Yes had it setup at 1080p, do have the new kaby lake beebox i3, and my TV set is a Samsung 65" JS8500. Now it worked for me before with and older recommended build, but with a Dell Inspiron Mini 3050.
I have only beebox 7200U (i5) with Intel Grafic driver 15.45.10.4542, which kodi build do you use now?
It's a HIT and MISSED situation when it comes to getting the Hardware Based activate on the KabyLake, this one of the issues i experience on the MSI Kaby Lake,
(2016-11-19, 22:41)movie78 Wrote: [ -> ]It's a HIT and MISSED situation when it comes to getting the Hardware Based activate on the KabyLake, this one of the issues i experience on the MSI Kaby Lake,
Yes but Caramba69 claims work on his beebox kaby lake based!!!
(2016-11-19, 22:38)Lucas Rey Wrote: [ -> ] (2016-11-19, 22:22)fmedrano1977 Wrote: [ -> ]Yes had it setup at 1080p, do have the new kaby lake beebox i3, and my TV set is a Samsung 65" JS8500. Now it worked for me before with and older recommended build, but with a Dell Inspiron Mini 3050.
Well got tired of messing with it, left it as is with latest provided driver by the Intel utility app, audio on the latest build shared a few post back.
Sent from my HTC 10
So, is there any solution for this issue?
It works here. I also can select hardware based. Please try Powerdvd to see if this is an issue with Kodi or with your hardware.
(2016-11-20, 11:13)Caramba69 Wrote: [ -> ]It works here. I also can select hardware based. Please try Powerdvd to see if this is an issue with Kodi or with your hardware.
For now I'm back to use the old method with
playercorefactory.xml, calling PowerDVD from Kodi. PowerDVD seems handle 3D without problem, but I cannot be sure because, as I said, I don't have now 3D TV. I'll continue my test next week when I have my new 3D TV.
What I don't understand is why in my beebox I cannot choose "hardware based" when you have the same hardware/software level!!!
Anyway, thanks for your time Caramba69....
I guess you need to have a connection to a TV that is capable of 3D.
Gesendet von iPad mit Tapatalk
(2016-11-20, 11:23)Caramba69 Wrote: [ -> ]I guess you need to have a connection to a TV that is capable of 3D.
But I have it and don't get that option.
Sent from my HTC 10
Can you try in Powerdvd if you can playback 3D in full 3D modus?
You also need to be sure to have a connection with the hdmi 1.4 port. You also can try different ports at your TV.
Hi, Problem with newest build: Skin Updates didn't work!
I dont know if this helps anyone
but i just tested the latest november build 17th november
intel hd 20.19.15.4531
win 10 ver 1607
Msi Cubi 3205U, WIn 10 With all the latest Updates. Only Windows drivers installed.
Tested 3D ISO, MKV, Bitstreaming 7.1 DTS HD MASTER and TRUE HD
Used Chapter Skip on 3D ISO, MKV etc
And happy to report everything working. Also all settings recommended on steps to take i.e. hardware based etc working.
Cpu Usuage was approx 10-15% on one cpu and similar on other cpu while in playback mode.
Very happy with this build
I also skipped through lots of menus etc looking for problems.
Did notice one thing but its probally my projector when exiting one time kodi it didnt go back to desktop so turned amp off and on and windows came back.
This only happened once when exiting enabled debug after and tried opening and closing kodi 10+ times and didnt happen again and no
problems during playback.
Thanks for this great software
I can skip, but it just messes up my audio. No idea why it freezes for you.
