Skank, the lip-sync error on DN2820FYKH is really a minor issue, but if you want to wait a day, I'll post impressions about Dell 3050. The Celeron J1800 in it is
supposed to be marginally faster (clock speed) than Celeron N2820, maybe just enough to avoid lip sync error in 3D ISO's.
(2016-04-04, 19:12)hdmkv Wrote: [ -> ]@Skank, the lip-sync error on DN2820FYKH is really a minor issue, but if you want to wait a day, I'll post impressions about Dell 3050. The Celeron J1800 in it is supposed to be marginally faster (clock speed) than Celeron N2820, maybe just enough to avoid lip sync error in 3D ISO's.
ill wait then
but if you say minor issue... mmm
My kid has a lip sink issue every time I take the car keys back.
It kinda' rolls down past her chin.
It's not an issue though.
I tell her to map 'A' and get that stiff upper lip in sync with the lower and all is well.
Short test conclusion: Full 3d ISO File= video & audio (DTS) OK
2d mkv 1080P = video OK
audio (DTS) very minimal out of sync.
Hardware:
TV = Samsung UE55H7000
Beamer = Epson TW 9200
Avr = Pioneer VSX 924
HTPC = Nuc6i3syk, 2x4GB RAM and 64GB m.2 SSD
OS: WIN10 pro
Latest Firmware with latest Intel beta chipset driver.
Kodi: latest Version from the 3d thread
Edit: Test with the 4 3d testfiles... everything is fine, no problems with 3d
(2016-04-04, 21:33)DeejayT Wrote: [ -> ]Short test conclusion: Full 3d ISO File= video & audio (DTS) OK
Hardware:
OS: WIN10 pro
Are you seeing any blurriness in 3D playback?
No the picture is perfect without artefacts
(2016-04-04, 21:45)DeejayT Wrote: [ -> ]No the picture is perfect without artefacts
Is this your settings NUC6i3SYK and Epson TW 9200 Projector?
(2016-04-04, 22:03)DeejayT Wrote: [ -> ]Yes
Hmm
Now something is telling me to buy back the NUC6i3SYK
(2016-04-04, 18:42)wesk05 Wrote: [ -> ] (2016-04-04, 18:30)noggin Wrote: [ -> ]That's odd. I always want lip sync. It's when stuff is out of lip sync I'm annoyed... Grrr... <Bangs head at wrong terminology being used>
When stuff is "lip-synced" or "in lip sync" or "has lip sync" it is perfect. When it "has lip sync errors", "is not lip-synced", or "is out of sync", things are wrong.
There appears to be a creeping use of 'lip sync' to mean 'lip sync errors'.
It looks like you are determined and not going to give up on this any time soon
Nope. There have been enough mutations of correct video terminology in PC circles, if I can do anything to keep things sensible (and so they also make sense in the video world) I will...
(Don't get me started on 'telecine' to mean adding 3:2 pulldown/repetition... And lag... Grr... Lag is the worst misuse... )
Btw. kodi does not do 3:2 pulldown.
The RenderManager was redesigned some time ago to implement a pull model. Renderthread comes by in refreshrate interval and asks for a frame to display. He then gets a frame which timestamp is not yet late. If you play 23.976 at 60 hz some frames are displayed twice or three times. As the renderqueue is elastic you should not realize any issues. The old 3:2 is long gone.
(2016-04-05, 00:09)fritsch Wrote: [ -> ]Btw. kodi does not do 3:2 pulldown.
No - my point is more that the word 'telecine' is used to mean 'add 3:2 pulldown' by many people. Whereas telecine is the machine and process of converting film to video.
In Europe we telecine 25fps film (or 24/23.976fps sped up to 25fps) to 50i/p using 2:2. It's only in 59.94Hz regions that their telecines use 3:2 (and for many years it has been done electronically rather than mechanically). The thing that really gets me is that now so little content is actually shot on film, very little footage is actually passed through a telecine. These days 3:2 pulldown is applied to 24p video, not just film, and this 3:2 pulldown has nothing to do with any telecine (Yet this addition of 3:2 is incorrectly described as being 'telecine' by many people...) The 'cine' in telecine refers to film...
Get's even worse when people start talking about 'telecine removal'...
Quote:The RenderManager was redesigned some time ago to implement a pull model. Renderthread comes by in refreshrate interval and asks for a frame to display. He then gets a frame which timestamp is not yet late. If you play 23.976 at 60 hz some frames are displayed twice or three times. As the renderqueue is elastic you should not realize any issues. The old 3:2 is long gone.
So all being well, with 23.976 sources and 59.94 output and no waiting for decoding what is the expected cadence?
(2016-04-04, 18:58)hdmkv Wrote: [ -> ]Lip sync error...
For budget options other than NUC DN2820FYKH:- Just tried Beelink BT3 (Atom X5-Z8300) ($132), a review sample from Everbuying, and it works surprisingly well. No HD audio bitstreaming, but full 7.1 multichannel output like RPi. I did have driver headaches w/BT3, but got them resolved. Will write a quick review later this week.
- Testing out Dell 3050 (Celeron J1800) (about $125 used off eBay) later today. This one should do HD audio bitstreaming.
Hi
What graphic driver did you use with your Beelink BT3 please? because the 3d doesn't work for me...
Thanks in advance
(2016-04-05, 14:45)tony_the_unik Wrote: [ -> ] (2016-04-04, 18:58)hdmkv Wrote: [ -> ]Lip sync error...
Hi
Thanks in advance
What kodi build are u running?
