(2016-04-19, 20:01)DeejayT Wrote: [ -> ]How is lipsync. Better?
It's the same as latest millhouse pi nightlies. When a video starts there's some immediate drop/adjustments but it's good to go after that.
Mmmm with my nuc6i3syk i have lipsync issue. And this Hardware have enough power.
No with previous Version. I will test 0419 today after work.
I'm seeing problems w/0419 build, similar to 0413... I hope @
afedchin is monitoring here...
Dell 3050 w/Celeron J1800:
- Major lip-sync error, some stuttering now, and even Kodi a little sluggish overall
If I enable debug logging, zero issues! No lip-sync error, no stutters. Seems due to debug's info overlay being present on top-left, helping sync
Debug log, but again, as playback was good w/logging enabled, I expect no issues will be seen in log
Intel NUC w/i3-4010U:
- Slight lip-sync error, some slight stuttering, and even Kodi slightly sluggish overall
If I enable debug logging, zero issues! No lip-sync error, no other issues (same as above). Again, debug's info overlay on top-left seems to help
Debug log, but as w/Dell above, as playback was good w/logging enabled, I expect no issues will be seen in log
hdmkv You need to make a change in advanced settings that allows you to be in debug mode without the overlay and then create the log. Afedchin linked to it in the other thread for timstephens. I'm in the drive thru line at mcdonalds or I'd find it for you lol!
Nice, and not
. Without dev support thread, no changelog, no debug logs.
We'll build 19 works great on my i5 nuc no issue build 20 works perfect on the dell 3050 guys be thankful we still have these builds coming.
I didn't get a chance to try 4/19 but 4/20 is looking awesome so far on my DN2820. If it does lose lip sync it must take much longer to happen. I'll know more for sure after a movie or two but at the moment I think this is by far the best build I've tested.
(2016-04-21, 03:46)Statikk Wrote: [ -> ]I didn't get a chance to try 4/19 but 4/20 is looking awesome so far on my DN2820. If it does lose lip sync it must take much longer to happen. I'll know more for sure after a movie or two but at the moment I think this is by far the best build I've tested.
I concur. It's smooth as a silent fart
on my DN2820 as well.
Though, one thing that I can't figure out. When I start a movie, I have the pop up that asks me which video mod I want to use to watch the movie. I can't remember which option I had it set to, with previous build as I didn't have this pop up.
I thought I remember reading that all 3 options needed where inside the 1st post in this thread but I can't find it...
