The 14 Jul build has finally fixed the issue with my Gigabyte Brix BXBT-1900 switching to 30Hz instead of 24Hz with 3D MVC films that I reported earlier, the workaround was to set the desktop refresh to 24Hz. So obviously the correct signal to switch to 24Hz with MVC files is now working, now I can set the desktop and Kodi back to 60p with smooth transitions.
That was the last issue on my box I was waiting to be fixed, thanks @
afedchin if this is one of your fixes on the changelog.
Hallo,
first gratulations for your great work.
Since release from July i have a great problem. 3D now works with my Epson Beamer (shutter technic) very well, as well as Atmos an DTSX do.
But my Library is in chaos. The thumbnails are different to the movies, a great confusion. I try to find the mistake the whole night, but i haven't any Chance.
If this can be fixed, Kodi has done a geat step forward.
Greetings
Peter
I have tried this with my amd powered pc. It works with libmfxsw32 pasted into Kodi. 3d image and audio are fine but there is a lot of frame dropping and and jerky playback.
The specs of my machine
AMD APU A6-6400K
MSI AMD Fm2+ A68HI
Ballistix Sport 16GB Kit (8GBx2)
Kingstone SSD
Am i missing a step/setting to get this to work smoothly
I love kodi but being able to play 3d MVC would be the icing on the cake
(2016-07-16, 11:40)Peter_C6 Wrote: [ -> ]But my Library is in chaos. The thumbnails are different to the movies, a great confusion. I try to find the mistake the whole night, but i haven't any Chance.
Greetings
Peter
I have the same problem with the latest Version.
(2016-07-16, 21:17)DeejayT Wrote: [ -> ] (2016-07-16, 11:40)Peter_C6 Wrote: [ -> ]But my Library is in chaos. The thumbnails are different to the movies, a great confusion. I try to find the mistake the whole night, but i haven't any Chance.
Greetings
Peter
With the 713 version I had, but with the 714 version the problem seems to be solved?
(2016-07-16, 22:26)p750mmx Wrote: [ -> ] (2016-07-16, 21:17)DeejayT Wrote: [ -> ] (2016-07-16, 11:40)Peter_C6 Wrote: [ -> ]But my Library is in chaos. The thumbnails are different to the movies, a great confusion. I try to find the mistake the whole night, but i haven't any Chance.
Greetings
Peter
First I thought so, but suddenly it was the same as in version 7/13.
Greetings
Atmos track and Dolby true hd is broken on last build can anyone check to see if it is working for them. Thanks
(2016-07-17, 00:37)bdreams Wrote: [ -> ]Atmos track and Dolby true hd is broken on last build can anyone check to see if it is working for them. Thanks
That really seems to be the case with last build. No HD-audio in display when testing several samples.
Edit: Just confirming, nothing else. No issue for me as I'm not a diehard Kodi user, still not my major media software.
I don't see a fast forward button in the default skin. Do I have to install estuary mod skin? How to skip chapters?
Also cannot check if I am viewing 720p or 1080p. Video description doesn't say anything.
TIA
Confirming issue with TrueHD and ATMOS in the 714 build. Play any TrueHD or ATMOS clip I've
posted to the wiki here in M2TS container... Kodi will either crash, playback is frozen, or there's no picture. So, any BD ISO with TrueHD/ATMOS seems to fail playing back as well. In MKV container is fine.
Guessing this is an issue with the new master on which this MVC build is based.
TrueHD is broken in master, we know, but it's currently not on top of the to be fixed list.
Please use trac so that is not forgotten.
This issue appears also in 16.1 master ? Or is it specific to 17 ?
Believe it's just 17... as TrueHD/ATMOS okay w/prior 17 builds, and final 16 master did TrueHD okay if I'm recalling correctly.
The other HD audio format that remains broken in 17 is Dolby Digital Plus passthrough.
(2016-07-20, 15:28)hdmkv Wrote: [ -> ]The other HD audio format that remains broken in 17 is Dolby Digital Plus passthrough.
Hmm... that doesn't make sense. You have mentioned in the WeTek Hub thread that Dolby Digital Plus works properly with the latest nightly on Hub with Marshmallow firmware. I haven't yet tried it on the Shield. Wasn't it broken on both Android and Windows versions?
