2009-09-24, 18:29
Kilack Wrote:I've been using MIP for quite sometime with tv shows.not sure why it's not working yet, but here's a workaround
It has never been able to scrap this show
"Digging for the Truth"
It always just says there is no data for it.
Taken straight from the screen after a scan
"No show data exists for the following shows:
However, of course on thetvdb.com it does exist and exactly in that spelling as I even copied and pasted from thetvdb.com. I can see nothing different about that show but for some reason MIP just won't pick it up.
xbmc scrapes it just fine.
Any chance you can take a couple of minutes fekker and see if you notice anything different about it on thetvdb.com that might cause mip to not find it?
thanks
create a text file called tvdbid.txt and put in 78863 in that file (with nothing else).. save that to the tv show directory, mip will detect that file and use the id in it for the show. UMM also uses these if no .nfo file is there
Quote:episode imagesstill no luck in figuring out why the api returns images that don't exist on the image mirror site, but i might be able to come up with a work around for those.
