kulprit Wrote:I think you missed my tv overwriting the nfo files that I already have fekker, on the previous page, I have read that it was just meant to rename these?
As long as it's a valid xml formated .nfo file, it should leave it alone. If it's not, it will remove it. It prob should have a rename option, just never added one.
Episode level is also going to update the first time when it adds media info.
2890 is up on mip update, it adds creation options for episode thumbnails and episode fanart directly from the media file using ffmpeg. This is designed for Serenity's new options that Digitalhigh is working on. It's still in the early stages and is slow as it has to get the images from the video, then resize them maintaining the aspect ratio, based off the display aspect ratio of the media as encoded. then it gives a dialog allowing selection of the episode thumbnail and episode background.
for some reason the text for the episode thumbnail doesn't show up, the top half is the episode thumbnail 720x480 size
the bottom half is the episode fanart 1280x720 size
gui feedback during creation is not done, it just sits there.. i'll work on that after I get all the other areas sorted out with it's creation and put it into another thread so the gui can tell ya it's working.
Quote:tvshow commandline
, i'll add a flag to hide the wget windows (i'm guessing that's what items your referring to)
Quote:No matter what I set the options to, MIP seems to download a whole bunch of images when a new show is added.
tvshow and bunch of images.. first run on a show it's going to grab all the images it can from tvdb.. if there's an insane amount, see if you have media images enabled, that can be a bunch more images.. after it has them once, you won't see the window again and it won't need to go after those images.
Music fanart, one thing checks your local folder for the music fanart pack (that's the auto assign one, since it's based on names) the other downloads it from htbackdrops.. once downloaded from htbackdrops, goto the background tab, pick on and click on it to assign it.. no automatic stuff on that yet, it's on the list
as for .nfo updates.. unless you set the option not to rename the .nfo file it's going to backup any non-xml formated .nfo files. if it's valid it will display it.
while mip and mc do things abit different, most .nfo's should be compatable.. got an example one for me to take a look at? (pastebin please)
think i got the questions covered, sorry if i've missed one, just bring it back up if so... not much time right now and spending what I can to get the new updates out the door.
