Hi all,
I'm using xbmc but my videos are so disorganized. I have movies, tv shows, and documentaries. Some of them are in folders, some aren't. I'd like to fix up my library so it looks good on the big screen when you run xbmc. Does this program help you do that?
I'm using 2.4.0.1 version and I'm getting an error (unhandled exception) whenever the app is trying to connect to imdb to retrieve info for any movie. Just in case I have added rules to allow the app to go thorugh the firewall but the error persists.
This is it:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at movieinfoplus.maincollection.wget(String& url, String& folder, String& id, Boolean wait, Int32 delay)
at movieinfoplus.maincollection.getimdbbyid(String& imdbid)
at movieinfoplus.maincollection.imdbparse(String& imdbid)
at movieinfoplus.modNfoData.checknfodata(movie& currentmovie, String dname, Boolean workonline)
at movieinfoplus.maincollection.autopilot(String primary, String secondary, Boolean posterTru, Boolean fanartTru, Boolean tbnTru, Boolean nfoTru, Boolean overwritenfoTru, Boolean replaceexsistingfolderimage, Boolean mediaonly, Boolean updatestudiofromimdb)
at movieinfoplus.maincollection.autopilotfromform(String primary, String secondary, Boolean posterTru, Boolean fanartTru, Boolean tbnTru, Boolean nfoTru, Boolean overwritenfoTru, Boolean overwritefolderjpg, Boolean mediaonly, Boolean& leavestudioalonedude)
at movieinfoplus.maincollection.bwAutopilot_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e)
at System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
at System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
mediainfoplus
Assembly Version: 2.4.0.2
Win32 Version: 2.4.0.2
CodeBase: file:///D:/Documents%20and%20Settings/xzmyz1/My%20Documents/Mis%20descargas/Movie%20Info%20Plus/mediainfoplus.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.3620 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
ComponentFactory.Krypton.Toolkit
Assembly Version: 4.3.2.0
Win32 Version: 4.3.2.0
CodeBase: file:///D:/Documents%20and%20Settings/xzmyz1/My%20Documents/Mis%20descargas/Movie%20Info%20Plus/ComponentFactory.Krypton.Toolkit.DLL
TabControlEX
Assembly Version: 0.0.3216.38616
Win32 Version: 0.0.3216.38616
CodeBase: file:///D:/Documents%20and%20Settings/xzmyz1/My%20Documents/Mis%20descargas/Movie%20Info%20Plus/TabControlEX.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
p_hyx7xb
tczcoqti
System.Web
Win32 Version: 2.0.50727.3618 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I will appreciate any help Thanks!!!!!
I can't get the bloody thing to install!
It gets almost to the end and then errors me with "Could not access network location C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup" ... even if I run it as administrator.
Why would Windows think somewhere on C: is a network location?
Oh, and forget about Universal Media Manager, too, the domain's expired and inaccessible.
Is there a way I can make the program save my fanart as "backdrop.jpg" instead of "fanart.jpg"? Possibly editing the config.xml or some other way?
It's a pity it cannot work on win7 64bit, i try it and always FC.
Is there really not an alternative to MIP? It is SO slow!!!
I'm using Ember for Movies, which works great, I like to add the covers etc. manually, but not for series. I don't want to choose which picture etc. I want, that's what MIP is doing well.
But - It's to slow.
Alternative?
wow... ungrateful much? Why not write your own program.
anyways....
I just recently started using XBMC again after 2 years. I have the new MIP and I was wondering...
XBMC scanned its own files in and I remember this happening when I used it before. They use to be located in xbmc...UserData/Thumbnails but I do not see that now in Eden. Can you please tell me how to clear my XBMC downloaded files so that it can read my MIP files?
Also it says that it cannot read my ATHF files as well as my Im With Busey files
Thank you!
(2011-10-22, 08:41)adsi Wrote: [ -> ]It's a pity it cannot work on win7 64bit, i try it and always FC.
Thats what Im using and it works fine
Not ungrateful, I just can't manage to get it working!
I use Ember for my movies, but it's too much of a hassle adding one episode at a time for TV-shows.
Atm MIP doesn't work at all. The CMD-windows never pop up, it's just locked.
And I couldn't understand anything in UMM, couldn't find any documentation. UMM is like MIP V2.0?
It doesn't seem to work at all with TheTVDB? It crashes when loading shows.
I have been using Media Info Plus. Its a great program. But as of 10-20-2012 it stopped working, App opens Ok, but when trying to update movies or tv, it goes to "not responding". I removed the last windows updates (windows 7- 32 bit - pro). Even removed app, deleted program folder and reinstalled. No change. This is a great program and thanks to all who worked on it. Dont want to try any others. Any ideas?
(2012-10-21, 20:51)bubbannj2 Wrote: [ -> ]I have been using Media Info Plus. Its a great program. But as of 10-20-2012 it stopped working, App opens Ok, but when trying to update movies or tv, it goes to "not responding". I removed the last windows updates (windows 7- 32 bit - pro). Even removed app, deleted program folder and reinstalled. No change. This is a great program and thanks to all who worked on it. Dont want to try any others. Any ideas?
same problem here, help please!!!
EMM is not a good option for TV Shows
I tried (only since yesterday),
MediaElch, and it looks very promising, and its developer seems to be very active.
