zeltak Wrote:Hi Fekker
Movie scraping works really well but i get this error:
http://pastebin.ca/1402669
when i load my tv shows every time
I might add im using it in virtualbox since i cant get it to work under linux and using the latest build 2248
thx
Zeltak
please update to 2884, known issue, recommend using mip update (available on website)
Quote:turbinez Is it possible to use MIP for my music and tvshows as well? I've been using it for movies and it works great but haven't tried using it for any other media yet. Does it pretty much work the same way as it does for movies?
similar, but different, more details in wiki on shows, in this thread on music
Quote:kulprit Based on your post above fekker, i was getting long names in the left hand window. I know its says it is not case sensitive, but I think to some extent it is. I put in a word that appears all in capitals in the folder name into the custom removal and it doesn't take it out. I tried in both the way it appears and all lower case
please send a list of files, 10 or so, so i can isolate issue
Quote:davemf Hey Fekker,
Apologies if this has been covered before, but how does MIP decide which movie files/folders to display on the left hand side list?
based on settings for where to find them.
file level based on file extension
folder level, every folder except ones filtered out
since your folder level, ensure you've picked top level folder.
movies
---300
---action
-----die hard
---wall-e
---etc
would pick up all those by adding movies to folder level in settings
it takes top level folders from settings and gets all sub folders in those, takes those sub folders and looks for any others, keeps going through all folders listed.
if they are not invalid, adds them to the list
here's the process in pseudo code
take folder from settings
get directory list for that folder
for each of those, get a list of sub directories
make sure it's not on the ignore list, if it's not then for each sub directory, get a list of it's sub directorys
keep going until we have all directories and sub directorys under the folder
now, take each foldername and make it a movie
For Each foldername In directory listing
parse just the movie name
If moviename = "con air" Or moviename = "" Or File.Exists in folder specialfolder.nfo Then
do nada
else
set up movie add to gui
end if
end for
the ignore list
is it a valid movie folder
Case Strings.Right(s, 3).ToLower = "cd1"
Return False
Case Strings.Right(s, 3).ToLower = "cd2"
Return False
Case Strings.Right(s, 3).ToLower = "cd3"
Return False
Case Strings.Right(s, 4).ToLower = "subs"
Return False
Case Strings.Right(s, 9).ToLower = "subtitles"
Return False
Case Strings.Right(s, 6).ToLower = "extras"
Return False
Case Strings.Right(s, 8).ToLower = "video_ts"
Return False
Case Strings.Right(s, 8).ToLower = "audio_ts"
Return False
Case Strings.Right(s, 7).ToLower = "trailer"
Return False
Case Strings.Right(s, 15).ToLower = "temporary files"
Return False
Case Strings.Right(s, 8).ToLower = "(noscan)"
Return False
Case Strings.Right(s, 6).ToLower = "sample"
Return False
Case Strings.Right(s, 8).ToUpper = "RECYCLER"
Return False
Case Strings.Right(s, 12).ToUpper = "$RECYCLE.BIN"
Return False
Case Strings.Right(s, 10).ToUpper = "LOST+FOUND"
Return False
Case s.ToLower.Contains("system volume information")
Return False
Case Else 'it's a valid directory and will be added and searched
Return True
Quote:turbinez I notice that MIP is causing Aeon Auriga list view to pop up with a "operation not permitted error"
I checked the xbmc.log and it said something about dialogok.xml
Not sure if MIP is writing incorrect stuff in the .nfo file to be causing this in Auriga's List View.
i'll need an xbmc debug log for this one, not sure what that's looking for
