fekker Wrote:that one doesn't have a studio listed on imdb so it didn't grab it.
Ok, another try at things.
- added net to studio line for episodes for skin based flagging
- fixed the error as noted below
- more checks and changes for file level items
Build 2833 - exefilesonly
http://www.mediafire.com/?otzjlm3ddzl
for the error.. I coded around it, and just for fun.. i translated the response to many many times through 4 or 5 languages to come up with the following.
"Zaproszenie do placówki nie było takiego przedmiotu." .. ok nie wiem dokładnie, dlaczego prostytutka się dzieje, ale .. Byłem kontroli na miejscu dla niego.
-- the first translation was this
"Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu." .. ok nie wiesz dokładnie dlaczego kurwa, że się dzieje, ale .. I've poddane kontroli w miejscu dla niego.
At least that was close to what I was saying.
Should it fix my problems too fekker?
I'll try it out right away.
Edit: Nope, I still get this error:
************** Undtagelsestekst **************
System.IO.IOException: Syntaksen i filnavnet, mappen eller diskenhedsnavnet er forkert.
ved System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
ved System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
ved System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
ved System.IO.StreamWriter.CreateFile(String path, Boolean append)
ved System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize)
ved System.IO.StreamWriter..ctor(String path)
ved movieinfoplus.mip.mov.Mov.writeMovXML(String folder, String filename)
ved movieinfoplus.movie.saveimdb2(movie& tmovie, Boolean writemovienfo, Boolean writemovienamedotnfo)
ved movieinfoplus.maincollection.autopilot(String primary, String secondary, Boolean posterTru, Boolean fanartTru, Boolean tbnTru, Boolean nfoTru, Boolean overwritenfoTru, Boolean replaceexsistingfolderimage, Boolean mediaonly)
ved movieinfoplus.maincollection.autopilotfromform(String primary, String secondary, Boolean posterTru, Boolean fanartTru, Boolean tbnTru, Boolean nfoTru, Boolean overwritenfoTru, Boolean overwritefolderjpg, Boolean mediaonly)
ved movieinfoplus.maincollection.bwAutopilot_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e)
ved System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
ved System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
