Note: please fill out bug and feature requests if you haven't already done so, i have very limited time right now and it makes it alot easier to sort out what needs to be fixed up / changed .. thanks!
2901 test patch is on the mip website (mediainfoplus.com), i didn't have time to run through testing, so give it a whirl and if somethings busted, please bug it on sourceforge.
Big NOTE: for slow tv show loading times, turn off the option to download episode images and see if that fixes it
some details and stuff on the patch..
Test build 2901 fix list
system volume information folder causing read scan to stop
wget windows being shown for tv show images (now set to show only when using the -debug flag)
reworded some output of tvshow command line to clean it up abit
added -fastimages option to tv show command line update
further cleanup of output of tv show command line, use -debug flag to see more info when it's running
added m2ts to supported extension for tv show command line
Added support for us.imdb links inside them eg
http://us.imdb.com/Title?0079944 -- regex (itle?\d{6,7})
Added additional error handling for music loading, errors are displayed in messagebox and should help isolate issue, in addition it may just skip that issue, depending on what is going on in the code.. please test
note: if mip can't find the movie, pick one from the dialog and then change the imdbid for that movie.
ubuntu wine errors, revert to recommended version in wiki, new version of wine crashes mip
RMVB file extension - added support to tv shows for .rmvb extension
fixed some missing extensions from command line (divx, .ts)
aired versus dvd order - have to research that one and modify when time allows, understand the issue
--Trying Media Info Plus for the first time, on WinXP 32bit. I have .NET 3.5
MIP 2.0.1.2870 installs, but I get this error after entering the path for my files and clicking "save config"
System.ArgumentOutOfRangeException: InvalidArgument=Value of '0' is not valid for 'index'.
hmm.. update before running the app, or just add one path in the wizard and after the app is open, add the rest.. not sure of exact issue or if you resolved it
me, theres a lot of problems with it , it would be better if there was a lite version theres a lot of features that nobody use there.
fix
*able to scrap individual shows with different language
-- not currently possible, feature for UMM
*loading time
-- system specific and option specific, details required, please add a bug to sourceforge with details
*when adding new shows it doesnt see them after click updateshows and load shows a few times
-- load shows rescans shows main folders and checks for new data from thetvdb.com .. this will find new shows
-- update shows scans for new episodes for shows already displayed in gui (i.e. doesn't look for new "shows" just new "episodes".. bad name on button, will change)
*sometimes it doesnt find fanart or movie info even when the info is in IMDB and in TheMoviedb
Mip uses imdb id number, make sure movie on themoviedb has imdb id in it (some are missing it)
*if you are choosing the fanart,poster,icons,nfo,ect... why it have to download the complete DB for each show/movie, in time you will have your computer fill with a lot of images that you dont use.(just download the one you choose delete the rest)
understand what your saying, best workaround is to specify the number of images and types you want in the config.. while it's alot of images, the disk use of it really isn't much compared to the movies / shows it supports
*the program is heavy (maybe because .net 3.5)
it's actually .net 2.0 and not 3.5 .. but yeah, it's got a bunch of options and some I went overboard on, the next big thing is UMM, just need some more time to sort out life stuff
*anyway after all this the program is a great tool.
- i like it, well most of it, some parts are annoying
__________________
