Hi
Nice to see how much work you put into this. What I can't figure out is why none of these windows scraper programs are as good as the xbmc scraper. I have my movies organized like this.
Top directory is called "Movies"
then all movies in their own subdir. All have scene release names. Then some movies are unpacked some are not (xbmc handles rared movies great, something I don't believe MC or MIP does). but let's keep this example to movies that I have unpacked!
-> Movies
--> Battle.In.Seattle.720p.Bluray.x264-SEPTiC
---> bis-septic.720p.bluray.dts.mkv
---> bis-septic.720p.bluray.dts.nfo
---> bis-septic.720p.bluray.dts.tbn
Now to my problem. What MIP should do is clean the folder name to get the actual movie name "Battle In Seattle" then scan the folder for files. As you see it already has all the files needed (exported from xbmc). It should use the existing files! and if I make changes it should overwrite the files.
What it does (MIP) is that it creates new files? based on the folder name, which is why MIP is a dealbreaker for me. I would love to use it to add media flags but I can't since it does not support xbmc way of scraping/naming.
this is what MIP does with my folder after I have clicked Battle.In.Seattle.720p.Bluray.x264-SEPTiC in the movie list:
-> Movies
---> Battle In Seattle 720p Bluray x264-SEPTiC.nfo
---> Battle In Seattle 720p Bluray x264-SEPTiC.tbn
---> bis-septic.720p.bluray.dts.nfo.oldversion
EDIT: It should use the video file name as reference, not the folder name. Same happens when you have a rared release. It creates fanart, tbn, nfo with the folder name not the name of the videofile inside the rars.
EDIT2: And as midgetspy said. Why can't it use the fanart, tbn and nfo that I already have in my folder? It always overwrites it with its own scanned version.
That is a mess
Any way to fix it?
EDIT3: What is the url to your SVN? I'm more of a c# programmer but would be nice to have a look at the code
