2009-10-14, 03:23
The sample is Lost Season 2.
Here is the season02.nfo generated when DVD (no) is selected:
http://pastebin.com/d389afb22
Here is the season02.nfo generated when AIR (yes) is selected:
http://pastebin.com/d64bf079b
I have to correct my previous statement. It does not generate any tbn/nfo files when DVD is selected. It's as if it doesn't recognize the episodes at all.
I tested this by removing all Season 2 related files and using 'Load Shows' while selecting DVD (no) when prompted. MIP generated the season02.nfo given above, the season02.tbn, and placed the folder.jpg inside the 'Season 2' directory. Of note is that Season 2 did not show up in the gui, presumably because it didn't recognize any episodes. I then removed the files it created and repeated the 'Load Shows' procedure, only this time selecting AIR (yes) at the prompt. This time around it generated the second season02.nfo linked to above, the season02.jpg, the folder.jpg inside the 'Season 2' directory, and all the expected nfo/tbn files for each episode. This time Season 2 did show up in the gui along with all the episodes for Season 2.
If I backup the episode specific nfo files, then drop them back in after selecting DVD order, MIP still does not see any of the episodes (or the entire season in the most cases as there are no episodes). If I had to guess I would say it is a problem with how it is building the episode list when set to DVD, possibly with how the DB is presenting the data. In the case of Lost Season 1 it does happen to pick up episode 25, but no others.
Notes:
1. These all work fine in build 2941
2. This test used build 2948
3. build 2946 seems to exhibit the same behavior as 2948.
4. Files were accessed via a mapped drive to a samba share.
5. OS is Windows 7 Ultimate x64, build 7600.
6. Clean install of 2870, followed by 2946 then 2948 updates.
Thank you for the program, it has made my TV library much more accessible via XBMC.
Notes:
