And with that comes this..
another new build!! yeah, wippie.. whatever
This is all fixes post 2801 to 2860, 99% of things should now be working correctly.
- known issues, the 3d box shot counter is on crack and reports back an insane amount of images when there is not that many
- special characters in folder names will cause the search to not find them, for those, please either leave them out, or put in the correct imdb id into the gui (or into a .nfo file)
New install build, should fix just about everything folks pointed out.
NOTE: you need to remove the imdb cached xmls, they are missing the certification information.
delete the folder C:\Program Files\mediainfoplus\cache\imdbcache\ .. it'll take awhile to delete that folder.
Let me say again
you must remove that folder and it's contents or you're missing out on two of the movies fields.. credits and certification.
Not sure what this is going to do under 64bit with fanart/movie poster resize or image tagging now that image magick is embedded, but try it and if it fails i'll come up with a workaround.
http://www.iamkizer.net/xbmc/mip/mip_ful...ev2861.rar
This is the full installer, no other files are necessary.. it should prompt you to remove the old version first, if not, no biggie, it'll overwrite the files.
For linux folks, or osx, i'll do a patch as well as a standalone (portable) version tommorrow.
mip_fullinstaller_rev2861.rar
