fekker Wrote:Worst case, find a field that can be pulled and we can change to another one.
Almost have the credits field done. I'm not sure what xbmc is looking for in that field.
see if this works for a movie and displays correctly (please )
<credits>John Lasseter / Joe Ranft / John Lasseter(story) & / Joe Ranft(story) & / Jorgen Klubien(story) / Dan Fogelman(screenplay) & / John Lasseter(screenplay) & / Joe Ranft(screenplay) & / Kiel Murray(screenplay) & / Phil Lorin(screenplay) & / Jorgen Klubien(screenplay) / Robert L. Baird additional screenplay material / Brenda Chapman story / Daniel Gerson additional screenplay material / Bonnie Hunt additional screenplay material / Don Lake additional screenplay material / Steve Purcell additional screenplay material / Dan Scanlon additional screenplay material</credits>
Holy balls dude! That's nice, but I don't think it's supposed to be that big.
http://www.themoviedb.org/movie/2789
Should just be whoever's listed under "author".
http://www.imdb.com/title/tt0296572/fullcredits#writers
Here it would be the "written by" field.
fekker Wrote:i use mediainfo.dll (the core of MediaInfo GUI) so it will show the same data, just not as much details.
.ts support for movies should already work, i checked the load routine and media scan routine for it..
does this fail for movies or something else?
You are right
On .ts it works already, just the "Media Folder Content" info window still display a red cross for Media.
.m2ts didnt work atm
fekker Wrote:see above post that i edited
hide wget windows should hide them, if some still pop and you don't want them to (ie configured not to display). let me know when it appears and I'll track it down.
I uncheck the show wget box but they still pop up.
bobrap Wrote:I uncheck the show wget box but they still pop up.
Check your config.xml and edit it to
<tv_showwgetwindows>false</tv_showwgetwindows>
maybe this help.
fekker Wrote:That's an example for Cars Writing credits .. they had alot of help it seems
http://www.imdb.com/title/tt0317219/fullcredits#writers
You are correct sir!
Yeah, for TV episode data, might as well throw it in the <director> field. Howabout putting the network name in there, res/audio stuff, and MPAA or other parental rating? That one doesn't pull through either...might as well use it.
I don't mean cause you any more headaches but I've noticed errors in the actors info.
IMDB - Samuel L. Jackson Sgt. Dan 'Hondo' Harrelson
NFO - Samuel L. Jackson Dan &#x27;Hondo&#x27; Harrelson
If I manually edit the NFO and change &#x27; to ' then it displays fine.
change - TV Shows Episode change to where the tagging stuff is going
added - Command line parameter to force an update is -nfoupdate
change - Ran cleanname on title and on actor name, that should strip out or change chars to something human readable.. well hopefully
change - Resized actor thumbs to a larger, actually visable size
added - Added full credits info -- you'll need to delete your imdb cached data
Director field for episodes now contains
director
mpaa
studio
all other tagdata
--- Exit MIP and either remove or rename C:\Program Files\mediainfoplus\cache\imdbcache
build 2830
http://www.mediafire.com/?nmteddjtztz
Oh yeah.. almost forgot
When your viewing your movies, if it's a file level movie, (one folder, lots of movies) .. a button will appear on the right, along with the movie information, that will allow you to move it to a folder automatically.. doesn't move all items in stacked movies, but does well with others... named .. "Move to Folder"
This takes the current movie and moves it's data, to a new folder in it's current directory. -big.png becomes movie.tbn .. other files are moved and copied for max compatibility.
If the movie is not a file level item, the button should not appear.
so if ya want to move to a folder format... enter your file level movies in the configuration, uncheck any folder level ones (to inactivate them) and go through your items.. after you have them all moved, you can move the path to folder level.
will there be a version for mac os x users?
turbinez Wrote:will there be a version for mac os x users?
It should work under wine for os x .. it for sure works under wine under ubuntu and wine under gentoo..
install wine
install .net 2.0 (i like wine tricks for doing that part)
install MIP
update MIP
there's more details in the wiki on wine install under ubuntu.. i'm guessing it's similar under os x
Just noticed the problem in actors is the role and not the name.
-- role is now cleaned up
-- changed -- Also, I renamed the button "Move to Folder" .. that's the new button that lets you move a file level movie to it's own folder auto magically.
-- fixed, error when reloading imdb data when clicking on refresh little green button
build 2831
This build will be made install a new install version later tonight, as well as the patch.
If you have already patched, you don't need to reinstall install with the new build.
http://www.mediafire.com/?qlzj3nlhjnt
Okay...So i just check my region (Australia) and it uses the info from there? How about the certification images?
