2009-04-02, 18:58
Ayla Wrote:fekker,
Using latest build: 2831, trying only to update media information, I get this error:
System.IO.IOException: Syntax in filename, folder or disk name is wrong.
ved System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
ved System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
ved System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
ved System.IO.StreamWriter.CreateFile(String path, Boolean append)
ved System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize)
ved System.IO.StreamWriter..ctor(String path)
ved movieinfoplus.mip.mov.Mov.writeMovXML(String folder, String filename)
ved movieinfoplus.movie.saveimdb2(movie& tmovie, Boolean writemovienfo, Boolean writemovienamedotnfo)
ved movieinfoplus.maincollection.autopilot(String primary, String secondary, Boolean posterTru, Boolean fanartTru, Boolean tbnTru, Boolean nfoTru, Boolean overwritenfoTru, Boolean replaceexsistingfolderimage, Boolean mediaonly)
ved movieinfoplus.maincollection.autopilotfromform(String primary, String secondary, Boolean posterTru, Boolean fanartTru, Boolean tbnTru, Boolean nfoTru, Boolean overwritenfoTru, Boolean overwritefolderjpg, Boolean mediaonly)
ved movieinfoplus.maincollection.bwAutopilot_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e)
ved System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
ved System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
Any ideas?
sounds like it's not finding the media file.
what is the filename of the media file for the movie this happens on?
is that in a folder, or file level?
