TV Show Loading / Status Logging...
Reading Folder Data
Processing: It_s Always Sunny IN Philadelphia
No TV Show data exsists for: It_s Always Sunny IN Philadelphia
Reading Folder Data
Processing: It s Always Sunny IN Philadelphia
No TV Show data exsists for: It s Always Sunny IN Philadelphia
Scanning / Update tv shows started
------------ 591----------------
Reading Folder Data
Reading Folder Data
That's all the data in my log file
fekker Wrote:hmm.. lots of things could be causing that one, can you run the gui part with debug enabled.
open config.xml = look for something that says debug for shows, set it to true
startup mip and goto shows
click on load tv shows
it'll pop a dialog and generate a txt file in mip's install directory
that debug log is what i'll need, it allows me to generate your file and folder structure (based on what ya have) to replicate the issue.
thanks!
fekker
