Anyone tried the changed installer? (2865)
does it work correctly?
I have a few patches, but they are based off 2865 and the new install, so i have not released them yet.
Ok
here's 2870 full installer
-- adds ofdb updates to movie information (this is found under the tools menu, for the currently displayed movie..)
-- go into the settings and choose which fields you want to update with that data
--Add's 0k file checks to command line and gui based tvshows, this should help when tvdb has a problem or returns nothing for the zip file
--contains the imdbid.txt file option
--fixes a bunch of little bugs that I noticed, nothing major
--add's additional output to command line tv show updates when you use the -debug flag on it
--fixes the impawards posters with the new format, run update known posters under the movie rename tab (i know, weird place) to update those known impaward posters (not necessary if doing a full install with no prior install of mip)
http://www.iamkizer.net/xbmc/mip/MediaIn...taller.zip
if your running
2801 to 2860 ... this should be a full patch to get you up to date
http://www.iamkizer.net/xbmc/mip/mediain...to_2870.7z
if your running
2861 or higher, try this one
http://www.iamkizer.net/xbmc/mip/mediain...xefiles.7z
when in doubt, use the full installer
if you didn't update to 2861 before today, make sure you clear out your imdb cache files or you'll be missing movie information (see first page for details on where that is)
if you need a portable version, grab the full installer on a windows box, install it, compress the directory and put it whereever ya like (before running it!)..
that should cover just about every version..
i haven't added the tv poster resize yet, it's on the list
also on the list is the bugged filter for file level movies
and of course the 3d box shots counter is still on crack
This is a much smaller installer, which i tested, but didn't hear back from anyone else.. should work, might not.
