New additional utility tool.. requires 2891 or higher build of MIP
(mip files are on mip's website ..
http://www.mediainfoplus.com in the downloads area
i put together a command line parser for it that generates the mystudios2.xml file for mip
studioconverter.exe is a command line app that converts Includes_MediaFlags.xml to mip's mystudio2.xml file
- save converter to some folder
- download the latest media flags and xml file
http://www.fernferret.com/xbmc/mediaflags/getFiles.php
- extract that file somewhere on your local machine..
- wherever ya extracted that file to, go into the 720p folder and copy the Includes_MediaFlags.xml to the same directory as studioconverter.exe
- copy the images to MIP's directory C:\Program Files\mediainfoplus\customimages\media\flags .. you will also want to copy the ones from one of the skins (Serenity and/or Aeon) to get the default other studio images
- run the tool to create mystudio2.xml
if you saved the converter and Includes_MediaFlags.xml to some other directory, just copy the mystudio2.xml to your MIP install folder
Now when your looking at your movies, and you click on the studio change button (to the right of the studio name) the list will have all available studios with images
pick the correct studio from the left list.. this will ensure it'll work in the skins as that's the list we just converted over
HUGE props to Halibutt and FernFerret .. they made the list and house the images.. i just made it work with MIP .. collaboration = good
example of mystudios2.xml (shortened version for example only)
<?xml version="1.0" encoding="utf-8"?>
<mystudios xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<version>1.02</version>
<mystudio>
<displayonly>false</displayonly>
<texture>flags/20thcenturyfox.png</texture>
<studioname>Fox</studioname>
</mystudio>
<mystudio>
<texture>flags/universal.png</texture>
<studioname>Universal</studioname>
</mystudio>
<mystudio>
<texture>flags/filmfour.png</texture>
<studioname>FilmFour</studioname>
</mystudio>
<mystudio>
<studioname>Channel Four</studioname>
</mystudio>
<mystudio>
<texture>flags/disney.png</texture>
<studioname>Disney</studioname>
</mystudio>
<mystudio>
<studioname>Pixar</studioname>
</mystudio>
</mystudios>
