Sorry to repost, i think my post got lost
Hi Fekker
First of all love the new ep thumbs feature, great work, but i can't get it to work, i'm using 64 bit OP/s and have installed ImageMagick as per the guide, but i get out of memory error whenever i click on an app without a thumb?
Also just wondered how are you progressing with the extra images?
And have you strated to implement the new Multiplex 16:9 thumbs yet?, there are quite a lot now on TVDB
One more thing and sorry to ask so much, any plans to intergrate trailers into MIP?
Thx
Lestat
Hi, I had a quick question...
Is it just me, or does MIP stop scanning folders for movies once it hits the System Volume Information? I see that it is supposed to skip that folder, but for me it doesn't scan for anything past that. I'm running windows 7, tried all the MIP versions I could find.
Sorry if this has already been covered
I'm not sure anyone mentioned that, but the latest version (2891) chokes on scanning TV Series. When scanning, CPU usage grows to 50% and memory usage grows well above 1,5 GB (WinXP 32). MIP finally loads the episodes and resumes working, but the memory usage seems way too high. Is it WAD?
Cheers
sumofatguy Wrote:Hi, I had a quick question...
This works for me on XP but MIP started to list the Recycle folders of my external harddiscs since I changed all my structure from file level to folder level. Furthermore I got one hell of a list of entries with "extrathumbs" which are needed for Aeon Auriga but I think this was mentioned before.
I got another issue with the episode thumbnail feature. The thumbnail preview are generated and shown perfectly (could you maybe code the extra window so that you see it in the windows taskbar coz it keeps appearing behind the open MIP window and I waited like 5 minutes till I found that out) but when I choose one of the 1280x720 thumbnails and click OK I ALWAYS end up with the first generated screenshot no matter what I chose before.
2897 up on mip update - bug fixes
Quote:Little bug regarding .ts support.
unable to reproduce, can you provide an example and mip version, try latest 2897 build
Quote:I have an issue with the actors, they don't get scraped properly. I scraped "In Good Company" and he got only 2 actors from it.
fixed, bug with regex
Quote:I'm noticing that the biggest problem with the other fanart is that it doesn't go away when you're viewing something that doesn't have an art image. I could really use a flag in the skin to tell me when it's there or not...if you haven't already done that.
hmm.. i didn't run into that one, does that happen with episodes too? (also this is in xbmc right?)
Quote:First of all love the new ep thumbs feature, great work, but i can't get it to work, i'm using 64 bit OP/s and have installed ImageMagick as per the guide, but i get out of memory error whenever i click on an app without a thumb?
try to resize a background or image or compress it, does that work? if so it' might be ffmpeg (in mip's root folder) is not 64bit
Quote:I'm not sure anyone mentioned that, but the latest version (2891) chokes on scanning TV Series. When scanning, CPU usage grows to 50% and memory usage grows well above 1,5 GB (WinXP 32). MIP finally loads the episodes and resumes working, but the memory usage seems way too high. Is it WAD?
Cheers
should not happen, my guess is that it's getting stuck on scanning media info
-start mip
-make fullscreen
-load shows
-when it hangs, what episode is it working on (top right of screen)
Quote:The thumbnail preview are generated and shown perfectly (could you maybe code the extra window so that you see it in the windows taskbar coz it keeps appearing behind the open MIP window and I waited like 5 minutes till I found that out) but when I choose one of the 1280x720 thumbnails and click OK I ALWAYS end up with the first generated screenshot no matter what I chose before.
add to show itself, also added bring to front on load of dialog,fixed a few resize issues with fanart's getting smaller size, double checked
selection option, could not reproduce, please re-test background issue with 2897
other things in build
added messagebox to warn when tv show is loading in debug mode
reworked folder and re-tested file level scans, added extrathumbs to ignore list, please retest if having issues with system volume info or recycle bin.
haven't added new features, just bug fixes
will see tommorrow about feature requests if i can
Just so you know, with 2897, it is creating an extrathumbs folder in every movie folder that is opened with MiP. Not a bad thing, will be ready when you copy the tv still grabbing across to movies.
fekker Wrote:should not happen, my guess is that it's getting stuck on scanning media info
-start mip
-make fullscreen
-load shows
Hmmm, something must've been wrong either with the file or rthe .nfo file. Initially it hanged on a single episode of a Polish series "Tajemnica twierdzy szyfrów" (S01E03; more importantly it was the only episode coded as .wma).
So, I went to that directory and deleted all .nfo files, rescanned and... guess what:
************** Tekst wyjątku **************
System.IO.FileNotFoundException: Nie można odnaleźć pliku 'C:\Program Files\MEDIA\MediaInfoPlus\temp\tvdb\Tajemnica twierdzy szyfrów.xml'.
Nazwa pliku: 'C:\Program Files\MEDIA\MediaInfoPlus\temp\tvdb\Tajemnica twierdzy szyfrów.xml'
w System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
w System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
w System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
w System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize)
w System.IO.StreamReader..ctor(String path)
w movieinfoplus.thetvdb.TVSeriesData.readTVSeriesXML(String xmllocationandfilename, TVSeriesData& vTVSeriesData)
w movieinfoplus.tvshowcollection.kbLoadTvShows(Boolean debugon, Boolean dlo)
w movieinfoplus.maincollection.tsbShowsLoadShows_Click(Object sender, EventArgs e)
w System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
w System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
w System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
w System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
w System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
w System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
w System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
w System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
w System.Windows.Forms.Control.WndProc(Message& m)
w System.Windows.Forms.ScrollableControl.WndProc(Message& m)
w System.Windows.Forms.ToolStrip.WndProc(Message& m)
w System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
w System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
w System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Zestawy załadowane **************
mscorlib
Wersja zestawu: 2.0.0.0
Wersja Win32: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
mediainfoplus
Wersja zestawu: 2.0.1.2898
Wersja Win32: 2.0.1.2898
CodeBase: file:///C:/Program%20Files/MEDIA/MediaInfoPlus/mediainfoplus.exe
Microsoft.VisualBasic
Wersja zestawu: 8.0.0.0
Wersja Win32: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Wersja Win32: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
ComponentFactory.Krypton.Toolkit
Wersja zestawu: 3.0.10.0
Wersja Win32: 3.0.10.0
CodeBase: file:///C:/Program%20Files/MEDIA/MediaInfoPlus/ComponentFactory.Krypton.Toolkit.DLL
TabControlEX
Wersja zestawu: 0.0.3216.38616
Wersja Win32: 0.0.3216.38616
CodeBase: file:///C:/Program%20Files/MEDIA/MediaInfoPlus/TabControlEX.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
4fktqyjc
eb8enq4i
xuzxmlav
21c5wgr3
pzz3y_xr
tj6tid44
miplibfc
Wersja zestawu: 2.0.1.2863
Wersja Win32: 2.0.1.2863
CodeBase: file:///C:/Program%20Files/MEDIA/MediaInfoPlus/miplibfc.DLL
eiqvedky
sjmr3vwg
System.Windows.Forms.resources
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll
So I restarted MIP (the latest version), scanned again and the program told me "No show data exists for the following shows:Tajemnica twierdzy szyfrów". Yet, the show does not get scanned, it's not on the list on the left, nothing, as if I deleted the entire series and not just the .nfo files.
Help...?
EDIT:/ Hint: restoring the .nfo files for all the episodes changes nothing, the MIP simply doesn't see them. And when I restore the tvshow.nfo - it get's back to "normal" - that is 1,6 GB memory used before it recovers.
Cheers
fekker Wrote:2897 up on mip update - bug fixes
Downloaded and installed a fresh copy and updated to 2898.
Created a folder on the Desktop called "test videos"
Created a folder called "Lost" within this
Copied a file into this folder called "Lost - S03E04 - This is a test.ts"
Let MIP do its thing on the "test videos folder
Ended up with:
Halibutt Wrote:Hmmm, something must've been wrong either with the file or rthe .nfo file. Initially it hanged on a single episode of a Polish series "Tajemnica twierdzy szyfrów" (S01E03; more importantly it was the only episode coded as .wma).
mscorlib
mediainfoplus
System
System.Drawing
System.Xml
mscorlib.resources
System.Data
TabControlEX
4fktqyjc
eb8enq4i
xuzxmlav
21c5wgr3
pzz3y_xr
tj6tid44
miplibfc
eiqvedky
sjmr3vwg
Help...?
Cheers
I'll have to see why mip gets stuck with that one when there's an .nfo there.. the other part of the issue, that shows the bug in mip, is that the tvdb api is not returning anything for that show
http://www.thetvdb.com/api/GetSeries.php...0szyfr%F3w
Quote:Just so you know, with 2897, it is creating an extrathumbs folder in every movie folder that is opened with MiP. Not a bad thing, will be ready when you copy the tv still grabbing across to movies.
woops, that was unintentional as it's part of what I'm working on with digitalhigh, something that's incomplete.
ahh.. gotca.. i was looking at movies and not tv shows
2898 will display more of the fanart from the tvdb.. including those new ones that are up there... limited to 36 backgrounds (up from 24) at the moment, will have to modify the save dialog to allow it to be saved as something else for skins.
fekker Wrote:double checked
Ah I just found out I misunderstood how this thing worked... I thought I had the option to select between smaller and larger thumbnails so I only chose a large one. Now I found out how it works, sorry for the inconvenience.
fekker Wrote:reworked folder and re-tested file level scans, added extrathumbs to ignore list, please retest if having issues with system volume info or recycle bin.
Nice work. I don't see any other folders getting identified as movies now but the ones I have.
the application is developing very well
can you tell us when we can expect the OFDb Update in the Auto-Pilot screen?
I also have some feature requests, can you tell me if they are possible?
1. Implement Moviemaze (
http://www.moviemaze.de) scraping, as they have a much better plot than OFDb. Perhaps with the option to select what information you want to use.
2. Use the runtime you get from the media file scanning, round it to minutes and copy it to the duration field. This would be very useful, because IMDB often gives you more than one runtimes.
3. Scrap Apple Trailers
http://www.apple.com/trailers/ for movie trailers.
4. Scrap GetVideoArtwork
http://www.getvideoartwork.com/ for movie posters.
5. Automatic create thumbnails for the new aeon multiplex view.
Now i found another "bug" / cosmetique failure
when MIP scraps IMDb for actor photos it also adds the link to the following photo in the nfo file :
http://i.media-imdb.com/images/tn15/addtiny.gif.
Having this white photos in the database is not very useful
Can you filter that out?
i tried what u said fekker, just did a resize it still failed, should i get a 64bit ffmepg?
anyone else have new thumbs feature working in 64bit O/S?
Halibutt Wrote:Strange: the show's most definitely there and the .nfo files that now cause trouble were created by MIP in the first place. Shall I send you the .nfos?
Cheers
my guess is that they changed something with the show and somehow it got lost.. i see the show is there, but when the api search is used, it fails to return anything.
Quote:tried what u said fekker, just did a resize it still failed, should i get a 64bit ffmepg?
it's something with image magick failing.
give this a try..
uninstall image magick
remove everything from the imagemagick folder (in mip's directory)
re-install image magick to that folder
give it another try.. maybe it's looking at 2 different versions (32 and 64 bit)
i know there was another guy here somewhere in the thread that got it working under 32bit
1. Implement Moviemaze (http://www.moviemaze.de) scraping, as they have a much better plot than OFDb. Perhaps with the option to select what information you want to use.
3. Scrap Apple Trailers http://www.apple.com/trailers/ for movie trailers.
4. Scrap GetVideoArtwork http://www.getvideoartwork.com/ for movie posters.
feature requests are good btw.. i'm not totally ignoring them, but have to fix bugs first, and finish up a tool for making fanart from media files. i'll address them when i get those done up and see what's doable and what has to wait.
fixing the white image when scraping actor photos, the runtime thing and ofdb in autopilot would be good
the other requests are not urgent.
perhaps scraping imdb for trailers would be doable faster, because there is a scraper available for that.
