rusten Wrote:After following this post for awhile, I've been very excited to test MIP. Today I had some time to give it a shot, and I have a simle bug-report, plus some basic observations/questions:
1) Simple Bug. When running for the first time, if you choose to add a file-level movie path (section two of the UI), it will get added to the folder-level listbox (section one).
should be fixed in newer builds, will depend on what installer version you used.
Quote:2) Bug/Question? I may be using it wrong, however, I have the "automatically rename" option checked, under settings, yet I do not see the movies being renamed. For exapmle, I was expecting something like "SEVEN_POUNDS_(2008)" to be renamed to "SEVEN POUNDS" based on the filter rules I have selected and the automatic-rename option being checked/active.
automatic renaming will only work for folder level items.
Quote:3) Question. Is here a tutorial/introduction? The info in this post is primarily technically oriented, not for a "how it's used" or "walkthrough" style piece. If not...
don't think there is one, i'm not too good at making them and mip changes so much they become outdated pretty quick.
if anyone wants to make a youtube video on how to use mip, that would be awesome! .. anyone.. Bueller? ..
Quote:4) Question. I'm a big confused about the overall workflow. Could you give a one or two sentence runthrough? For example, I was assumign the workflow would be something like this:
a) set target-paths
b) choose options
c) execute bulk application on chosen paths based on options
d) browse the results, passively (non-destructively)
However, when I actually ran this.. the "Auto Pilot" does seem to go through every movie, yet it does not seem to load everything. The entire load does not appear to happen until I select each movie. I then chose Pre-Cache, but I noticed in the process, there was another weird behavior -- that every time I selected a file (that had already been loaded) it would *re-load* the data off the Internet (scrape).
I would describe the process as this
install mip, pick your folders for movies shows and tunes
go into the setup and configuration and configure the images you want to download, if your not sure what a setting does, or how xbmc handles data, don't start randomly unchecking things
click on pre-cache on movies to download all the images, if an .nfo is not found you will be prompted to select it
after pre-cache is completed, run auto-pilot to assign the images and .nfo files for your movies
when that is completed, exit and restart MIP .. (this is due to glitch when it loads movie data from .nfo files and some tag information. only needed the first time something is being setup)
start MIP and load your movies, then use the left side filters (movies with problems, missing .nfo, etc..).. i would start with missing .nfo as the other items are based on that
continue with the other filters until your movies are setup the way ya like.
shows... load shows button, wait for everything to finish downloading (it'll take awhile)..
music..
use the music sorting wizard to sort your music to a DIFFERENT FOLDER.. i say this so you can see where mip is going to think your music is.
use mp3tag to sort out the music files (from the folder you used the music sorting wizard to output).. i recommend this because i can't touch drm'd files.
It allows rewriting of tags that MIP can't touch.. i.e. all the DRM'd files.. MIP can only inject or modify tags on mp3 files.. blame drm, when i modify them without loading a bunch of windows crap and drm junk, the files become unusable.. and when i load all the windows stuff that allows me to modify them, i'm stuck with .net 3.5 (which i don't like at all, and it doesn't work in wine).
music note: mip matches based on exact matching ..
Green Day
GreenDay
those are not the same name, mip will put them into different folders.
Quote:5) Question. Is there some option I'm missing, to create the database in a separate directory (which I could map to XBMC's userdata path, etc) so that my .ISO's are not co-mingled with the .tbn/.nfo/fanart, etc?
not currently an option, they have to be with the file or xbmc will not load them.. it's also how mip is coded.. i guess you could get trickey with symlinks under linux, but what a pain that would be to do
Quote:Thank you in advance!!
your welcome
