Oh, almost forgot: a feature request. Some software when ripping DVDs add a "extras" folder. While MIP handles VIDEO_TS and AUDIO_TS subfolders just fine, this Extras subfolder appears as a separate movie on the list. Should be easy to correct though I believe.
Cheers
I am getting the same error as the other user when I try to run mediainfoplus.exe. I tried 3 different versions (2801, 2830 & 2831). Am I missing something?
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: mediainfoplus.exe
Problem Signature 02: 2.0.0.2830
Problem Signature 03: 49d3f8fb
Problem Signature 04: mediainfoplus
Problem Signature 05: 2.0.0.2830
Problem Signature 06: 49d3f8fb
Problem Signature 07: 4e
Problem Signature 08: e0
Problem Signature 09: System.InvalidOperationException
OS Version: 6.0.6001.2.1.0.256.6
Locale ID: 1033
Edit: Never mind. Just realized I need to install from the original installer.
Any chance of another download link as there is a problem with the mediafire link? thanks
Just to let everybody know. I have spoke with fekker over the past few days and gave access to a domain that I don't use to often and when hes ready we will have another place to host this app. I figure hes given a lot and I myself have clicked on that paypal donation button in the app once before and I encourage others to do so as well because he's earned it.
Anyways just thought I'd speak up and let you guys know.
Pray my host doesn't kill me for this. Hahahahahaha
Here we go, fresh build for yas.
Notes: Studio still can get kinda funky sometimes, i'll have to go back over all of that again, but it's better.
added -- studio change option, you can change the studio with the new button beside the studio name for movies
- -- i'd recommend you clear everything and then add in the studio ya want..
- -- if you want a studio that's not in that list.. edit mystudios.xml in the root of the install folder for MIP.
fixed -- Fixed mip not saving updates to .nfo files
Build 2835 - update file only (extract to install path)
http://www.iamkizer.net/xbmc/mip/mediain...esonly.zip
thanks kizer!
I'll have to get a copy of the installer up there as well
I'm using the latest build linked here and I'm having an impossible time updating the studio when I enable the tagging that works with Aeon. Quite often the studio in IMDB isn't who I want it come up as so I need to update that, yet no matter what I do every time I hit save for the NFO the original studio is in there (from IMDB), not the one I enter manually.
Anyone else experiencing this?
Halibutt Wrote:Oh, almost forgot: a feature request. Some software when ripping DVDs add a "extras" folder. While MIP handles VIDEO_TS and AUDIO_TS subfolders just fine, this Extras subfolder appears as a separate movie on the list. Should be easy to correct though I believe.
Cheers
Put an empty file called specialfolder.nfo in there (for movies) and MIP will ignore it
For tvshows, the ignore file is "noscan" (no extension, just the text noscan)
parrots Wrote:I'm using the latest build linked here and I'm having an impossible time updating the studio when I enable the tagging that works with Aeon. Quite often the studio in IMDB isn't who I want it come up as so I need to update that, yet no matter what I do every time I hit save for the NFO the original studio is in there (from IMDB), not the one I enter manually.
grab 2835 and click on the new button.. i'd recommend you clear everything and then add in the studio ya want..
fekker Wrote:Put an empty file called specialfolder.nfo in there (for movies) and MIP will ignore it
Thanks for the tip.
Actually I was thinking of a way to set this in the options menu - to disable Extras folder scanning by default. However, this may indeed be a wrong idea as there are some movies of that title as well and it's not worth the effort to implement it.
Cheers
Sorry but can u put up a link to the installer the other one appears to be down
fekker Wrote:can you pastebin an example .nfo and the movie filename, i'll isolate the problem.
Movie name: A.Few.Good.Men.BluRay.mkv
NFO name: A.Few.Good.Men.BluRay.nfo
NFO contents:
http://pastebin.com/m227ff5ff
All of my NFOs were generated with Media Companion. MIP seems to know they exist (there's a green checkmark beside everything but Trailer at the bottom of the list) but it doesn't use any of the info and doesn't update them.
Hi Fekker
Not sure if you missed my message as there are so many to you
I checked if I could hit that server on 8080 and it works fine, can view the image etc.
Anything else I can try? I tried turning on debug mode but it basically made mip freeze up for 30 minutes and the tvshowdebug.log only had 1 line in it.
If you have any ideas it would be much appreciated.
This new version looks amazing, great work
Does the monitor function work yet?
