Hi everyone,
Complete noob!!! here and i was wondering whether someone could help me regarding xwmm!!
The problem im having is i am trying to create movie sets via tools menu but i am unable to add or remove sets.
The add and remove buttons don't work
Hopefully someone can put me right cos im about to pull my hair out
Many thanks
(2013-05-25, 21:01)talbotpjt Wrote: [ -> ]Hi everyone,
Many thanks
Managing movie sets is listed on the first post as unsupported at the moment
will there be a new Version for XBMC 12 ? ore just the one from zernables ? I realy miss the Genre funktion
Nothing seems to appear in the TV section - Movies appears to be working fine. I am using 2.1.0. Maybe the problem is that I am using XBMC 13-alpha.
Also is there a way to make Tools|Export to HTML include the full filename and path?
I'm running XWMM in Eden and want to know if there is a way of changing the Movie Set Thumbnail from when I access the XWMM browser from my PC?
Thanks in advance
Hey, how to edit the certification for a movie?
Anyone mind helping me out. I can't seem to get this working. When I navigate to the index file, I get file not found. I'm running XBMC 12.2. Is there anything else I should have done / am doing other than what I have below:
1) Download
XWMM-210.zip and install in XBMC
2) Allow control XBMC via HTTP
3) Navigate to IP (I just use
http://localhost:80/xwmm/index.html)
Am I missing anything?
XWMM Version 2.0.9 running on Eden.
I can't seem to add a plot longer than about 80 characters. Simple English characters, no special characters. I saw a thread on this forum from 2011, but I wonder if it was fixed in some version and just mine isn't working..
(2013-06-26, 06:36)codeseven Wrote: [ -> ]Anyone mind helping me out. I can't seem to get this working. When I navigate to the index file, I get file not found. I'm running XBMC 12.2. Is there anything else I should have done / am doing other than what I have below:
1) Download XWMM-210.zip and install in XBMC
3) Navigate to IP (I just use http://localhost:80/xwmm/index.html)
did you go to setting>services>webserver tab and switch your web interface from default to xwmm?
Hi everyone
Does anyone know when "menage movie sets" will start working ?
Thank you
(2013-06-30, 23:34)EWENEMENT1981 Wrote: [ -> ]Hi everyone
Thank you
hoping for this too
I still need to clean my whole DB and waiting for this to make it much easier than from the TV :-p
tx
Count me in. I've delayed the move to Frodo until this is working.
I also put off moving to frodo for the same reason, but got impatient and ended up updating. I can't get it to work at all now. My movies show up on the left but there is nothing else. None of the fields are populated and there are no genres listed. What gives?
This not working on frodo is my only reason for still being on eden.
