francovilar Wrote:I have the same issue (except the renaming part)!
also the sort title isn't working and the original title doesn't save.
Will look into this as well
slash Wrote:I'll try to replicate the problem.
Thanks for your feed back
I have the same problem with latest nightly Eden. And I also find that I can not change the Movie's Title and Genres's name. It just remain the same in XBMC. Hope that you can check this out slash
Is there an option to install the latest SVN version on an Xbox?
Joster Wrote:Is there an option to install the latest SVN version on an Xbox?
You have to use the manual method: download, unzip and copy in the web directory.
slash Wrote:You have to use the manual method: download, unzip and copy in the web directory.
Ok, terrific. I wasn't sure about that because of the "svn" in the version name
I'll give it a try tonight (I hope).
Joster Wrote:Ok, terrific. I wasn't sure about that because of the "svn" in the version name
Result: one big white screen
I want to say that XWMM is my favourite manager, thanks for your hard work.
I have just one question,
Do you plan add support for
- change thumbnail and fanart for TV Shows ?
cheers
Yes Slash thanks for all your hard work
Hi everyone,
Just posted svn 2.0.0d. It should fix some bugs mentioned lately:
-- Movie Set save function
-- Sort Title save
Thanks to all for your encouragements, support and help. It keeps me motivated to work on XWMM.
Let me know how this release goes.
slash
castortray Wrote:Hi,
cheers
Yes but didn't have time to work on it. Was focus on fixing some bugs.
Thanks for your patience
slash Wrote:Hi everyone,
-- Sort Title save
slash
Hi slash, just tried the latest svn on my atv2, and it seems you got rid of the bugs from 2.0.0c, or at least the ones I reported! Great work man, this is a must for any xbmc user
Edit:
Unable to save title edits or make changes to any of the main info ie plot, outline, tagline etc.
Burbulence Wrote:Edit:
Damn, I thought I fixed those.
Sorry
will fix it asap
-- Sort Title save
slash
Thank you. The sort title is working but there's a cosmetic issue:
Set sortitle to movie "A" then save. choose another movie and return to "A", the sort title is blank. I have to refresh the movie list to show the sort title field.
slash Wrote:Damn, I thought I fixed those.
Sorry will fix it asap
Well done. Many thx. Trying~~
