no, this is not the way to use addon, should be name webinterface.XWMM
to install it, in addon --> install from zip, it will be installed in addon directory, then go and activate the desired webinterface in networ settings.
Thank you for info !
Quote:then go and activate the desired webinterface in networ settings
How to do that in dharma beta 2
go in network settings... and open your eyes
Hello
I open my eyes
Quote:the desired webinterface
With my eyes wide open I can't see no XWMM webinterface.
I saw only a few services :
maybe you wanted to say to enable webinterface for controlling xbmc
Just I did.
When I asked about how to select the desired "webinterface.XWMM" I thought it was like the add-ons.
I thought the Network-Settings have a list of several "WebInterface" and you can choose one of them. And one of them was XWMM.
That's what I look and I could not find.
XWMM not work as add-on for me.
How did you manage to make it work like an add-on to Lucid + Dharma beta 2?
There is no notifier for successfully installation after you install from zip.
Any way there is a "webinterface.XWMM" folder in "/home/pricinosus/.xbmc/addons" after install.
What is the next step to make it work?
For me works only with folder XWMM in "/usr/share/xbmc/web/"
Look here:
Respect
strange, are you running beta2 ?
It looks like beta 1 instead of beta 2.
slash Wrote:Instructions:
Method 1: (XWMM will be the only web interface)
- Go to System > Add-ons > Install from zip file
- Select the downloaded Download webinterface.XWMM-x-x-x.zip file
- Go to System > Settings > Network > Services:
- Allow control XBMC via HTTP
- Web interface : XWMM
- open your browser to http://<your_XBMC_IP>:<port>
Method 2 : (if you use multiple web tools) (due to XBMC limitation will be fixed in Eden)
- Copy webinterface.XWMM in the user directory to webinterface.default/XWMM in the XBMC directory
- Web interface : Default
- open your browser to http://<your_XBMC_IP>:<port>/XWMM.index.html
Trying both of the directions above (which worked perfect 'till the end
), I only see the default interface.
My info:
- Linux 2.6.32-24-generic (Ubuntu-Lucid)
- XBMC 10.0-beta2 r33778 (Compiled: Sept 14 2010) (PPA build)
With method 2 (using default web interface), could you try opening the browser at :
http://<your_XBMC_IP>:<port>/XWMM/index.html (I made a typo in the how-to)
If it still doesn't work, please send us the result of :
ls -al /usr/share/xbmc/addons/webinterface.default
prompts me to type in user name and password.
then it tells me "File not Found"
I am using google Chrome as my browser
xbmc@XBMCLive:~$ ls -al /usr/share/xbmc/addons/webinterface.default
total 32
drwxr-xr-x 5 root root 4096 2010-09-14 14:20 .
drwxr-xr-x 37 root root 4096 2010-09-14 14:20 ..
-rw-r--r-- 1 root root 778 2010-09-14 01:18 addon.xml
drwxr-xr-x 2 root root 4096 2010-09-14 14:20 css
-rw-r--r-- 1 root root 1150 2010-09-14 01:18 favicon.ico
drwxr-xr-x 2 root root 4096 2010-09-14 14:20 images
-rw-r--r-- 1 root root 2816 2010-09-14 01:18 index.html
drwxr-xr-x 2 root root 4096 2010-09-14 14:20 js
xbmc@XBMCLive:~$
when going into the addons in xbmc I didn't see XWMM in there to be downloaded
pre Dharma Beta2 it was working just fine for me
-=Jason=-
Does this now handle creating nfo's and saving covers and fanart ?
Flomaster Wrote:http://<your_XBMC_IP>:<port>/XWMM/index.html
total 32
xbmc@XBMCLive:~$
-=Jason=-
slash Wrote:Method 2 : (if you use multiple web tools) (due to XBMC limitation will be fixed in Eden)
- open your browser to http://<your_XBMC_IP>:<port>/XWMM/index.html
You didn't follow method 2 correctly.
sudo cp -R ~/.xbmc/addons/webinterface.XWMM /usr/share/xbmc/addons/webinterface.default/XWMM
I don't have ~/.xbmc/addons/webinterface.XWMM
-=Jason=-
After installing the webinterface.XWMM-x-x-x.zip-file, the directory ~/.xbmc/addons/webinterface.XWMM should exist. Are you sure you have installed XWMM via the Add-on-Menu?
I was tinkering with this last night (windows 7).
In my userdata/addons I only had folder called XWMM (not webinterface.XWMM)
But when I copies XWMM folder from the userdata folder and dropped it in to addons/webinterface.default/ it worked fine.
put it in webinterface.XWMM
then select it in options.
