Thanks slash... its been helpful for me.
Do you know if you'll have the ability to add content-type to the folders?
mlrtime3 Wrote:Thanks slash... its been helpful for me.
Working on it. Will let you know when it is done.
Slash,
I like the ability to export the movies list to html so I can print out a list to make it easy for the family to choose what movie to watch. How can I change the "video" and "audio" to resolution and channels? I want to be able to look at the list and see which ones are HD and surround vs. SD and 2 channel? Can you help me?
Geoffrey
geoffreyjr Wrote:Slash,
Geoffrey
H,
You could modify the export.js file for your needs and use JSON-RPC with getmovies method.
Let me know how it goes.
slash Wrote:H,
I read up on that and it is way over my head. I am not much of a programmer, i just wanted to hack the export.js to get the resolution (video width) and the audio channels.
I know this is the code I need to change:
GetVideoStreams(myRecord);
GetAudioStreams(myRecord);
myWin.document.write("<td>"+myRecord.data.strVideoCodec+"</td>");
myWin.document.write("<td>"+myRecord.data.strAudioCodec+"</td>");
I just dont know what to change it to.
~g
geoffreyjr Wrote:I read up on that and it is way over my head. I am not much of a programmer, i just wanted to hack the export.js to get the resolution (video width) and the audio channels.
~g
Ok, added to feature requests.
thanks
This is a nice addon.
Two questions:
1. If I have a movie that has a wrong runtime, and I change it it in XWMM it won't show up in XBMC even if I refresh. Am I doing something wrong?
2. Is it possible to make a quest account which is read only?
Bjur Wrote:1. If I have a movie that has a wrong runtime, and I change it it in XWMM it won't show up in XBMC even if I refresh. Am I doing something wrong?
You need to do a save (click in an other field and save button will be enabled).
Let me know
Bjur Wrote:2. Is it possible to make a quest account which is read only?
Guest account for (catalogue) is in the roadmap but not yet available.
I apologize in advance .. I just registered and still need to dig through all the pages. I just installed xwmm and it's really quite cool.
Can this tool (or maybe another) merge genres in a simple way. I am thinking of a function where you are asked which genre should be used instead of the genre you are just deleting.
br
Daniello
I also just found this tool and need to read through all the posts but: is there a way this could be installed on the server acting as a NAS ( has apache2 and other services too ) instead of on xbmc box itself? The server has sabnzbd, couchpotato,... that kind of stuff so it would make more sense to have this on it also.
daniello Wrote:I apologize in advance .. I just registered and still need to dig through all the pages. I just installed xwmm and it's really quite cool.
br
Daniello
No not for the moment, but I think a script would be more appropriate for this.
A work around could be to rename the genre you want to change, but I'm not sure if this would do it for you.
dzan Wrote:Hi,
I think it could be installed on a seperate web server but I don't see why such setup would be more efficient. Could you provide more pointers ?
In any way, I added the XBMC parameters to the features requests (right now XWMM assumes XBMC is local).
slash Wrote:I think it could be installed on a seperate web server but I don't see why such setup would be more efficient. Could you provide more pointers ?
Quite simple: My server is always running, my htpc isn't. I would like to manage my media collection even when the htpc is off..
dzan Wrote:Quite simple: My server is always running, my htpc isn't. I would like to manage my media collection even when the htpc is off..
The media collection itself is stored on the HTPC, so even if the web front-end is on another server, it won't be able to access the database when the HTPC is off.
Am I right, Slash?
Slash,
I recently got my first HTPC running and I love the XWMM interface. However, I would like to suggest a few enhancements. I initially thought I'd fork the project for my own use, but I'd rather try to contribute back to the project.
I'm quite experienced with ExtJS myself, so I can jump right in. Can I post a list of enhancments on the Sourceforge bug list?
thanks,
Francois
