Maybe I am missing something here, but is there any possibility to do the following:
Have a list of all movie filenames, the attached scraped titles and IMDB IDs? It seems like the IMDB scraper gets movies very wrong sometimes and I would ideally want to update the IMDB ID by hand then and kick the scraper to update the saved data...
Edit: I am using 2.0.0d on pre Eden, FWIW.
nupi Wrote:Maybe I am missing something here, but is there any possibility to do the following:
It is work in progress. working on adding the scraper methods in JSON-RPC.
josh.lawless Wrote:I can't get the 2.0.0d version to work --
I have succesfully installed 1.9.4 through the XBMC addons interface.
I downloaded the 2.0.0d version (via the command line on my XBMC Live install), unzipped it, and replaced the webinterface.XWMM folder from the 1.9.4 installation with the folder I unzipped from the 2.0.0d archive.
Now when I access the web page, the Javascript doesn't seem to run -- the page loads, I can view source and see the html (and the web page title and favicon.ico are properly displayed), but the rendered page is just a blank white background.
I've checked permisssions, they're the same between the new 2.0.0d webinterface.XWMM folder and the old 1.9.4 webinterface.XWMM.bak folder. Any reason why the new version shouldn't work?
Tried on Firefox 7.0.1 from Windows XP and on Safari from OSX 10.7
what version of XBMC are you running ?
slash Wrote:what version of XBMC are you running ?
XBMC Live Dharma Stable.
According to System Info: "XBMC 10.1 Git:Unknown (Compiled : Mar 9 2011)"
Operating System Linux 2.6.32-26-generic #48-Ubuntu
josh.lawless Wrote:XBMC Live Dharma Stable.
XWMM 2.0.0d is compatible only with XBMC pre-eden nightly builds. It uses the JSON-RPC API.
For the messages you have with 1.9.4 I'll have a look at them.
Joster Wrote:Result: one big white screen
Is this an Xbox issue (because Xbmc4Xbox isn't compatible?)?
slash Wrote:XWMM 2.0.0d is compatible only with XBMC pre-eden nightly builds. It uses the JSON-RPC API.
Well, that explains it.
I saw that 2.0.0d was "(pre-eden compatible)" -- I didn't realize a pre-eden build was required.
josh.lawless Wrote:Well, that explains it.
Sorry for the confusion. I'll modify the first post accordingly.
I am receiving the following JavaScript errors in IE as well, using 2.0.0.d:
SCRIPT5007: Unable to get value of the property 'id': object is null or undefined
ext-all.js, line 11 character 157212
SCRIPT1028: Expected identifier, string or number
movie.js, line 44 character 2
SCRIPT5009: 'Movie' is undefined
startapp.js, line 102 character 3
Firefox 5.01 works but i am unable to double click on images, when i try to i get this..
getting the following javascript errors:
this.data is undefined
this.proxy is undefined
all in ext-all.js line 7
My build info:
Built on Oct 24 2011 (Git:20111023-0e8168e, compiler 1600)
Thanks for the great work!
Cool, I've been wanting to put my movies in to sets for a while, this helped me get in done in minutes.
One question - I have my movie list sorted by year newest at the top, this means movie sets are bumped to the top of my list as and when they are made. Is it possible to add a year to the set (or use the year from first or last movie in the set)?
Kevo Wrote:Cool, I've been wanting to put my movies in to sets for a while, this helped me get in done in minutes.
+1 Would be really nice to have.
Am I missing something or is it not possible to edit cast with the current version?
tungmeister Wrote:Am I missing something or is it not possible to edit cast with the current version?
There is partial support for Cast in Tools / Actors
Feel free to make suggestions.
+1.....what a lifesaver......thanks
hi what am i doing wrong i installed it set it to default web interface and enabled conrtol ofer http and local programs have control over xbmc
now i go to my browser and tap in
http://xbmcip:8080
now i got a login window did it and came to a black window where initialize XBMC.lib.... was written and that for ever didn`t change
