ijourneaux Wrote:Was just trying out XWMM. Installed fine. I can load up the webpage in the browser fine.
Unfortunately when I click on the Movies button, the busy icon starts rotating and the interface never comes back.
I have a lrage media library. Perhaps it just takes a long time?
Take Care
If you have a large media library it will take longer (rotating icon) but it should not take too long.
Could you open your browser with :
http://<your_xbmc_ip>:<port>//xbmcCmds/xbmcHttp?command=queryvideodatabase(select movieview.idMovie, strFilename, c10, c00, strPath, c14, idFile, playCount, c07, sets.idSet, strSet FROM movieview LEFT OUTER JOIN setlinkmovie ON movieview.idMovie = setlinkmovie.idMovie LEFT OUTER JOIN sets ON setlinkmovie.idSet = sets.idSet)
copy the page source and post it here, using pastebin.com
Just updated to Beta 4 and installed this from the addon repo. Really good so far. Only had a chance to check out the movie info so far, but I'm having a little issue.
When looking at the list of movies, the movie sets icon and the watched status icons are shown on all movies - i know for a fact that they should not be.
I've tried this in both Safari 5.0 and Camino 2.0 on OS X and Firefox 3.6 on Vista and I'm getting the same issue across all 3 browsers.
Any Ideas?
Other than this 1 small issue this is looking like a fantastic tool.
tyersch Wrote:Hi,
Any Ideas?
I didn't have a chance to check XWMM with beta4. I'll look into it.
Changes :
- Fixes :
- Fixed genre list display was not always showing in TV Shows
- Fixed episode list not always showing
- Added :
- Scraper list is created dynamicly from installed add-ons
- Fanart display in Movie interface
Tested with Beta 4.
let me know
Is this update in the addons repo, or will it require a manual update?
At work at the moment, but will test in Beta 4 when i get home.
Still seeing the same problem with the movie sets and watched flags using 1.9.2 on Beta 4.
Any way that i can try and help identify the issue?
tyersch Wrote:Is this update in the addons repo, or will it require a manual update?
Not yet available with the official repo. Will submit this week.
tyersch Wrote:Hi,
Strange, I have the same setup and don't have the issue.
- try to set the movie to unwatched (select movie, right-click) and refresh the page how does it come back ?
- try with movies by genre and recently added. Do you have the same issue ?
- Try this from a browser, copy-past the result source page using pastebin.
http://<ip_xbmc>:<port>/xbmcCmds/xbmcHttp?command=queryvideodatabase(select movie.idMovie, strFilename, strGenre, c00, strPath, c14, movie.idFile, playCount, sets.idSet, strSet FROM movie JOIN files ON (movie.idFile = files.idFile) Join path ON (files.idPath = path.idPath) LEFT OUTER Join genrelinkmovie ON (genrelinkmovie.idMovie = movie.idMovie) LEFT OUTER JOIN genre ON (genrelinkmovie.idGenre = genre.idGenre) LEFT OUTER JOIN setlinkmovie ON movie.idMovie = setlinkmovie.idMovie LEFT OUTER JOIN sets ON setlinkmovie.idSet = sets.idSet)
We are looking at the 7th field of each record (playcount) should be empty or 0 if not watched.
Quote:- try to set the movie to unwatched (select movie, right-click) and refresh the page how does it come back ?
After a refresh the watch tick returns. Also does not update the watched status in the XBMC Movie Library,
Quote:- try with movies by genre and recently added. Do you have the same issue ?
Having the same issues in Movies by Genre.
Watched Status issue is still there under Recently Added, but the Movie Sets flagging is correct.
Quote:- Try this from a browser
http://pastebin.com/3sUGKYQu
Just a thought... Could this be linked to me using a MySQL database?
Cheers
Looks like an awesome app!
Sorry if this is a n00b question. Does this Web Addon scape the media information such as fan art, movie posters, Tv/Movie info to the directories where the actual movies/tv shows are stored, like ember media manager or is it saved directly on the XBMC media box. I stream all my content from a Freenas server and kind like how each directory contains all the information. Not to mention it reduces the hassle of having to always re-scrape content when upgrades are done etc....
This is a wonderful tool!
Just one thing: I can't seem to replace covers with for example locally stored images. Is this supported?
Thanks,
t
tyersch Wrote:http://pastebin.com/3sUGKYQu
Cheers
Hi again,
your pastebin does not contain the XML tags (<record>, <field>, etc ..). You need to copy paste the source page : when you execute the url I gave you, go into view / page source, and copy that content into pastebin.
Also, do you have the watched tag set in the XBMC interface or just in XWMM ?
As for the MySQL question, I'm not sure as I use only the standard SQLite setup. May be someone else using MySQL could jump in.
Quote:your pastebin does not contain the XML tags (<record>, <field>, etc ..). You need to copy paste the source page
Sorry. Didn't realise you wanted teh page source. will put this on paste bin when i get home from work.
Quote:Also, do you have the watched tag set in the XBMC interface or just in XWMM ?
Tags are set for the majority in XBMC, but the are 20+ that are unwatched. I've checked these ones in XWMM and they are set to watched.
