Now I'm just fucked....lol
Every view EXCEPT Landscape and 3D Landscape show the proper image for Season 3 and Season 4.
Images:
Correct (In the fact that it's using the correct images....)
Incorrect
Quote:Looks like ListItem.Label spits out what you'd like:
EXACTLY !
But this view i can't choose, is this just a suggestion look ? or can I do this also ?
mcborzu, could you add the Add-ons menu as a submenu of settings? I like to have access to it, but i dont want to clutter up my home menu.
Also, i am not sure if this have been brought to your attention, but when viewing tv shows in the wall view, the TV show name is placed in the upper right corner, directly under the clock and other info making them overlap.
Not quite sure if this is a bug, looks ok, was just getting some genre fanart happening and havn't been in the genre section for a while
MovieGenre maybe
Steveb Wrote:Not quite sure if this is a bug, looks ok, was just getting some genre fanart happening and havn't been in the genre section for a while
MovieGenre maybe
Well I included the code for Genre Fanart but didn't included images so thats weird...Though in the pic I noticed "movieset" shows up when it's not supposed to.
TehMaster Wrote:mcborzu, could you add the Add-ons menu as a submenu of settings? I like to have access to it, but i dont want to clutter up my home menu.
1. That has to stay as it the "Program/Addons" section. But maybe on the submenu...
2. Good catch...I don't venture into "Files" mode much.
mcborzu Wrote:Well I included the code for Genre Fanart but didn't included images so thats weird...Though in the pic I noticed "movieset" shows up when it's not supposed to.
The fanart image is one I put together in a pack, sorry for the confusion, it was a bit late and I had a few bevies by then
and yes I thought Movieset should be MovieGenre.
Anyway to have a "fallback" cdArt if one doesn't exist in the album folder?
the tvshow logos are missing on episode level, should they?
zwat Wrote:the tvshow logos are missing on episode level, should they?
Need more info - what view or all views? Screenshot?
My guess is the episode(s) is in a folder like so:
Lost/
Season 1/
Episode 13/
s01e13.avi
if it's like that the logo wont show
landscape fanart and yes the folderstructure is like that. anyway to force logo if available?
When I go to videos - add source- then select the folder that has my Tv Shows and back out. I am not getting the Tv Show selection on the home screen nor does it show any episode information when i select a series.
Casanova_32210 Wrote:When I go to videos - add source- then select the folder that has my Tv Shows and back out. I am not getting the Tv Show selection on the home screen nor does it show any episode information when i select a series.
you have to add the source .. and then scan the source
after you add the source go to video's .. highlight your tv source .. hit 'c' .. "scan for new content"
the video add-ons menu don't have global clock.
