Hi all, im loving the latest XBMC release and of course the night theme but im I being totally stupid in that I cant seem to be able to switch between movie displays... ie list, multiplex, wall etc.
Any help would be awesome. im using Dharma 3 with latest ver of night.
GAMe Wrote:Hi all, im loving the latest XBMC release and of course the night theme but im I being totally stupid in that I cant seem to be able to switch between movie displays... ie list, multiplex, wall etc.
Just press opposite way you're navigating. Some views the scrollbar comes up just press that same way again...
How do i get the lyrics button to the MusicOSD??
I enabled it in the settings and set the path for it, but it doesn't show the button in the OSD.
P.S. Absolutely love this skin, keep up the good work.
Thanks first for the very beautiful skin.
I have one problem, I downloaded the skin yesterday from the addons, I did not see the option Live tv, it was present when using the default skin. I use live tv to stream from my VDR. How I can enable it please? Thanks again.
Best Regards
Sami
sami8519 Wrote:Hi,
Best Regards
Sami
To my knowledge this skin isn't set for the PVR branch
Oh it is a bit of shame because I have fallen in love with it. Thanks mate for your help.
Regards
Sami
Thus far I'm still unable to see the next air date for any series in any of the skin views.
The plugin runs at startup and I'm positive it works because I can bring up the plugin itself and see info there.
I build xbmc daily from git and pull night every other day so I'm up to date.
Even tried a completely fresh download of the skin from git to no avail.
I don't know what kind of info I can provide as far as logs because like I said the plugin is working but I'm at a loss for why it doesn't show in the skin.
please post a debug log, well try to see
I hate you sometimes. :p
*edit* And it's spontaneously working... ffs
that's one of my magic
I don't think this look right?
yep, looks like I overlooked that cast section...
Small bug - Search is misspelled in the context menu at the bottom of the movie view screen. It is spelled 'Seasch'.
not actually a bug, but moviegenre has the black border on both sides instead of a filled out image. the filled out image looks hell of a lot better.
You can add in the config menu option to remove "press left to see trailer", as there are people who do not use the default scraper and FilmAffinity example does not work. only causes discomfort when pressed by mistake.
Add I see some errors in the latest versions of night.
Greetings.
