2010-11-06, 15:11
toby77jo Wrote:Hi,rename default-layout.php to layout.php and make sure your web-server has write access to it (I am not sure why chmod 777 isn't working for you but I'm thinking you haven't renamed the file to layout.php).
As of 2 days the sicbeard page is empty, anyone see something bad on my config? aldo the Control does not work, give me file not found..
Also chaning position of any dashboard give popup :problem saving layout, file not writeable, and i have done chmod -R 777 on my entire www dir:
The default links in Control widget are not supposed to work, they are part of my own setup which are not generic, I left them as examples. You need to add your own shortcuts to things you find useful by editing config.php.
