Are you using the IP address or the Host name? I tried the hostname and was not recognised.
Here are all my settings.
config.php
$transmission_url = "http://192.168.0.13:9091/transmission/rpc"; // The url for transmission webserver
$transmission_admin = "xbmc"; // The username for trasmission webui
$transmission_pass = "xbmc"; // The password for the webui
My Navlink
$navlink["Transmission"] = "http://xbmc:xbmc@xbmclive:9091/transmission/web/";
My JSON Settings. (/etc/transmission-daemon/settings.json)
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"dht-enabled": true,
"download-dir": "/home/xbmc/Downloads/torrents",
"download-limit": 100,
"download-limit-enabled": 0,
"encryption": 1,
"incomplete-dir": "/home/xbmc/Downloads",
"incomplete-dir-enabled": false,
"lazy-bitfield-enabled": true,
"max-peers-global": 200,
"message-level": 2,
"open-file-limit": 32,
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": 0,
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"ratio-limit": 2.0000,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{b3d0450d9bb5a6dab3f91b5a8fb96d5a5fed97a58WRBrLsY",
"rpc-port": 9091,
"rpc-username": "xbmc",
"rpc-whitelist": "127.0.0.1,192.168.*.*",
"rpc-whitelist-enabled": true,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"umask": 18,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14
My XBMC is setup on XBMCLive on a Acer Revo living on 192.168.0.13 (XBMCLive) Transmission is now available from every machine on my network.
All I need now is -
"watch-dir": "/mnt/NZBs",
"watch-dir-enabled": true
to add and everything will be perfect. When I do, I get parser errors.
Hope that helps. I found setting the json.settings an absolute nightmare. Transmission believes in far too much security IMO, especially when I only use it behind a router.
EDIT - Watch directory sorted. Had to add a comma after upload slots section. Doh!
EDIT 2 - This a bit of nightmare to setup. Now I'm struggling with permissions for the folder creating when adding torrents.
sudo chmod g+rw /home/xbmc/Downloads/torrents
didnt work work! Grrr.
