oneadvent Wrote:root@joshsphone:/var/www/html $ git clone git://github.com/mediafrontpage/mediafrontpage.git /var/www/html/xbmc/
Cloning into /var/www/html/xbmc...
fatal: remote error:
Could not find Repository mediafrontpage/mediafrontpage
My bad - case SenSiTivE
git clone [noparse]
[email protected]:MediaFrontPage/mediafrontpage.git[/noparse] /var/www/html/xbmc
Got it, but it still says no
I didn't do the change file name, cause it said it couldn't be created.
http://imgur.com/30zAP
You have it installed now.
All you need to do is CHMOD the files so they have write access.
chmod 777 /var/www -R
Then click the reload button.
Excellent that works. Can we update the front page for others though?
DejaVu Wrote:You have it installed now.
No! 777 is not safe! don't advise that. Especially not in the root of /var/www, it will open up all rights on subfolders/files for the world to access if the port is open.
Best practice:
chown -R www-data /var/www/mediafrontpage (to make it work)
chmod -R 774 /var/www/mediafrontpage (to enable git pull-updates)
Does anyone have reverse proxies working correctly in MFP? I had them working previously, but after a new HTPC rebuild I can't get them to work at all. I'm not sure if I'm missing something with a PHP setting or an Apache module, but it's driving me crazy.
The details -
- SAB/SickBeard/CouchPotato/HeadPhones/XBMC are all setup with working reverse proxies in Apache. All have been verified to work correctly internally & externally from my network.
- MFP setup always passes fine and page loads, but no info gets displayed in the widgets. The Nav links do work when pointing them to my external website/proxy (ex.
http://www.servername/sab/ loads SAB webUI fine)
- Apache modules loaded are
Quote:Alias, Auth_basic, Authn_file, authz_default, authz_groupfile, authz_host, authz_user, deflate, dir, env, headers, mime, php5, proxy, proxy_connect, proxy_http, reqtimeout, setenvif
- PHP5 & PHP5-curl are installed. extension=curl.so is enabled in the php.ini
- I've gone as far as removing/disabling all security to ensure that wasn't causing the issue. Mod_security & Mod_Evasive are disabled. I've chmod'ed the var/www/mfp directory to 777. Tried various settings of having the owner of the directory as www-data, root and my user.
- Tried every possible combination of internal/external settings in MFP for the Global, Program & Reverse Proxy settings.
- I've tried both the official repo and Deja's repo with the same results.
If anyone who has MFP working with reverse proxies could post what Apache modules and MFP settings they're using, I'd really appreciate it. Thanks.
Aenima99x Wrote:Does anyone have reverse proxies working correctly in MFP? I had them working previously, but after a new HTPC rebuild I can't get them to work at all. I'm not sure if I'm missing something with a PHP setting or an Apache module, but it's driving me crazy
Which repo are you using? The official one should work well with reverse-proxies (at least it does for me). Deja's is only partially working for me these days.
Has anyone written a guide to configuring this? I tried searching the 200 pages on this thread but no luck.
I am specifically looking for details on the config.php
Cheers
David
steve1977 Wrote:Which repo are you using? The official one should work well with reverse-proxies (at least it does for me). Deja's is only partially working for me these days.
Tried both.....neither is working.
Paraffin Wrote:Has anyone written a guide to configuring this? I tried searching the 200 pages on this thread but no luck.
Cheers
David
DejaVu repo has it when you install it on your server and get it up and running it does a system check to verify that you have everything installed to display the site. After that you continue with configuration thru the website which makes it alot easier.
Are you using Apache? If so, what modules do you have loaded, I'm wondering I'm missing one.
Aenima99x Wrote:Tried both.....neither is working.
Go for the official repo to get it running. Would suggest not to "touch" your apache settings because they used to work before (I haven't touched mine in ages). Make sure that you have it configured right in the config GUI.
1) Make sure that you delete all user names and password from the individual programs
2) Check that you have reverse proxies and master user-name and PW activated
3) Include all relevant info under reverse-proxy settings (for SB for example right only "TV" without the "", etc.)
steve1977 Wrote:Go for the official repo to get it running. Would suggest not to "touch" your apache settings because they used to work before (I haven't touched mine in ages). Make sure that you have it configured right in the config GUI.
Yeah that's how it's all setup. Global config points to my external url, master username & p/w are enabled, nothing in any of the individual programs except for the SAB API key and reverse proxy settings all have the correct webroots.
