2011-05-20, 02:55
Hey Deja, thanks for the pointer. I've made several versions of the widget but none of them were good enough to me. I quite like that slideshow you showed me. Seems to be pretty simple as well, will give it a try when I have some time.
Also wanted to ask you to have a look at the CrazyLayout branch as I seem to be doing something similar to you with one big difference: the way I implemented doesn't need multiple versions of the same widget to apply them to different pages and it was only a minor change in the code so no overcomplicating anything. Have a look and let me know what you think. To access the different 'workspaces' you call mediafrontpage.php?layout=WORKSPACENAME where the name is layout-WORKSPACENAME.php this way it is pretty easy to extend as many layouts as one may want. Have a look and let me know what you think.
Since all of them were already answered I just want to say 4 is a good idea, and I don't think it would be hard to make. Just a simple iFrame of sorts I guess. Will give it a try.
Are you sure you can't just open XAMPP control panel and in settings you can tell it to start on boot? Or just put it in the startup folder? I think that's how I had it when I was using W7.
Seems to me that you need to enable CURL. Probably in php.ini or something. A quick google search would probably tell you the answer.
DejaVu Wrote:Hey Gugahoi.
I know it's a WIP and is likely to have a complete overhaul (and I'm planning to learn how it works - hopefully with a few pointers).
The trakt widget has been looking 'ugly' on my screen for a while and had to change the Scroll to Auto.
Minor, but looks a lot better.
Any updates on this lately? Any objections to getting rid of that grayed out scroll bar on the Official Repo?
--EDIT--
Also, although Coverflow looks good, it is a little hard to recognise the covers IMO.
would it be worth simplifying it and using something like this instead -
http://www.dynamicdrive.com/dynamicindex...tslide.htm
This images are clickable and Add to CP could be added to the links...?
branlr Wrote:Man this project is really awesome...
4. Widget to simply load an entire webpage, and then allow cropping/locking into place. This is a really cool way to grab some content, to me.
steve1977 Wrote:Thanks. Unfortunately, I cannot find a service called xamppapache or something similar after executing services.msc. Anyone using xampp with an idea how the service is called or what to do?
castortray Wrote:Hi all,
I just started using MediaFrontPage but I have this error:
Thanks for any tips
