3 Reasonable sized
updates from me for today.
1 - Removed the forcing of Mobile Interface (I need confirmation for this).
2 - Fixed Enable/Disable Site Widgets 'Widget'.
3 - Added most of the support for AutoMovies.
I need a little help getting this to run on XBMCLive, but I think for the most part, it should be ready to go.
Also added the ability to Reload the page on the Program Check after changes have been made to the settings. (REFRESH).
If your already on my Repo - go to Settings and click Update.
BACKUP your config.ini file before you do.
Just incase.
To Add AutoMovies to the NavBar use the following in your Nav Settings
Quote:AutoMovies / programs.php?p=AutoMovies
Installing from fresh? It will already exist.
@steve1977
I think I'm going to have a lot of problems trying to fix reverse proxies on the whole. For a start, it does not matter how many times I try to get it working - I fail!
Bugs
1) scroll bar of "coming episodes" not functioning -
I do not have any problems with the scroller at all - works perfectly in Chrome. I've literally passed on Firefox, it's going downhill rapidly.
2) program check does not work if reverse proxies are used (programs work though) -
Cannot get in a position to test this out. Reverse Proxy is a PITA for me.
3) user name and PW are openly displayed in the "coming episodes" widget on mouse-over -
My SB has it's pants down all the time. Think there has been a fix for this and thought I had applied it - will tackle this tomorrow.
4) "Site widgets" being displayed and cannot be removed in settings-widgets-activatewidgets". -
Whoop! WIN - Fixed.
5) Movie and TV show library do not show alphabetically in widget -
This I thought was also fixed - mine does.
6) Harddisk settings doesn't work properly yet. I cannot delete the first entry in the list (will automatically re-appear after saving). Also (separate bug), when adding more than 10 disks, the "buttons" will go out of the screen view, so that I cannot save changes or include names/locations.-
You cannot hide the first entry (and make it empty), it breaks the widget - why would you want to delete the first entry? Replace it with your C:\ Root/ or USB Drive no? 10 HDD's?!!? We did not really expect someone to have 10 HDD's and can see this angle was not approached. EASY PEASY FIX - Buy bigger HDD's! I have 6 x2TB's and am struggling to find things to fill them with now.
Feature requests
1) fully-working "mobile version" including all widgets
The architecture for the mobile version was created sometime ago by someone that no longer works on MFP, I'm thinking it might need completely replacing!
2) squeezebox widget to play audio
Never heard of it.
3) subsonic widget for audio
Great idea and one I shall look into. Which will help improve my Widget skills too.
4) subsonic widget to ply video
Perhaps - but I think VLC Web Interface streamer would be far better, I think Subsonic's trial thingy for streaming has a time limit doesnt it?
