DejaVu77 Wrote:Can an 'Add Movie to CouchPotato' Widget be created using the information from this thread?
http://couchpotato.lighthouseapp.com/pro...ctionality
It seems as though it would to me...
Note to self
LEARN MORE ABOUT CREATING STUFF. I find it quite frustrating I cannot bend my head around some of this!
How would that work?
Currently, I installed the MediaMonkey script in CP which does allow you to add a movie from a movie site like IMDB, sharethe.tv, themoviedb, etc. It is quite nice and it lets you select resolution. It is in CP > Settings > Userscript.
I have also told CP where my Sab downloads\complete\Movies folder is. When a download is done in Sab and it was NOT initiated by CP, CP still finds the movie, adds the metadata, and updates the XBMC library.
With the above in mind, when I get movies via non-SABnzbd methods, I simply drop the movie into the above Sab folder, and all the cataloging work is done by CP. I hate to say that I tend to find movies faster than CP does. This is probably becuase I obsess over this whole thing...
Note to self
DejaVu77 Wrote:An insight into what I was planning here -
https://couchpotato.tenderapp.com/discus...solve=true
Great find DejaVu! I think this helps a lot with the development of CP widget!
On another note: is anyone able to test the Transmission branch? I think the widget is already as functional as the Sab widget with some extras. The extras would be colour coding (red means paused, green means downloading) and there's the always usefull popup on hover with some extra details. But I wanted to have people testing it before adding to the master branch.
On side pannel
On main panel
I think this goes without saying really... But - HOLY **** Gugahoi - that is Awesome.
I love the way it ties in with SabNZBd. So much so, it may be better to replace the uTorrent one where possible.
Looking at that the one I 'hacked' in, has far too much pointless info...!
Simply, yet functional - loads better!
gugahoi Wrote:Great find DejaVu! I think this helps a lot with the development of CP widget!
On side pannel
On main panel
i wish utorrent widget looked like the Transmission lol
DejaVu77 Wrote:I think this goes without saying really... But - HOLY **** Gugahoi - that is Awesome.
RaNaMaster Wrote:i wish utorrent widget looked like the Transmission lol
Thanks guys. Did a couple more updates today. Now it is possible to set download and upload speed straight from the widget! I think it is good enough for prime time, will probably merge the branch.
Already started working on a jDownloader widget. Couldn't find an API of sorts so I started using regular HTTP method calls to JD Remote Control Add-on.
If anyone knows where the actual API is, it would help greatly, otherwise it doesn't seem like there is much to be done there.
Cheers.
JDownloader! That would be awesome!! Will you be able to add files or just monitor the downloads?
i dont know if this is going to help with the utorrent widget but i found something n it looks like it can help us but im no coder but here it is take a look at it please
download utui
Hey guys,
check it out!!! ->
https://github.com/gugahoi/mediafrontpag...Downloader
Not very functional yet. You can start/stop the entire queue, but don't know if it's possible to do individual downloads yet (I don't think it is). Go on and grab that and give me some feedback please!
hernandito Wrote:JDownloader! That would be awesome!! Will you be able to add files or just monitor the downloads?
It's possible from what I see. Don't know how I'm going to implement that yet or how difficult it is.
RaNaMaster Wrote:i dont know if this is going to help with the utorrent widget but i found something n it looks like it can help us but im no coder but here it is take a look at it please download utui
I was actually using that to develop it until DejaVu fixed his widget. It is quite useful.
Another thing I wanted to say is that the Transmission Widget is now officially in the master Git. And also wanted to show a couple of things I added to it.
The widget doesn't throw crazy php errors if the program is closed or the address is wrong.
Also added two text boxes that let you check/set the download and upload speed in Transmission.
gugahoi Wrote:Another thing I wanted to say is that the Transmission Widget is now officially in the master Git. And also wanted to show a couple of things I added to it.
Thank you Guga....
I installed Transmission in my unRAID server. It is configured and working as I can (on a remote computer) see the web interface at this link:
http://192.168.0.201:9091/transmission/web
I entered this in my config.php
//Transmission info
$transmission_url = "http://192.168.0.201:9091/transmission/web";
$transmission_admin = "myname";
$transmission_pass = "secret";
I copied your wTransmission.php file to my widgets folder. And I also copied the folder TransmissionComponents also to widget folder.
I added the widget to my layout.php.
When I go to MFP, I see the transmission widget, but it is completely empty... there is no text displaying or anything else. I also tried downloading your entire master branch, and running it just changing to my config.php file, and I had the same results. So I am guessing it is something in the config.php file.
Any ideas.
Many thanks again for all your awesome work.
Ignore this. Posted in wrong place.
I can't seem to get the JDownloader Widget to work. I've got the config pointing to the remote control.
Quote://jDownloader info
$jd_url = "http://192.168.1.2:10025/"; // url to jDownloader Remote Control port
If I access
http://192.168.1.2:10025/ within my broswer I get "JDRemoteControl - Malformed request. Use /help". Although as far as I can see it's working fine.
Hopefully it's just something simple on my part that I can work out.
hernandito Wrote:Thank you Guga....
//Transmission info
Any ideas.
You should use
http://ip:port/transmission/rpc
And not /web
It still should show up the warning. Let me know. Maybe also check permissions on the files?
