2011-06-01, 16:34
drunkendragon Wrote:1. Do I edit the size of the scrollbar in scrollbar.css ?
2. When i've time i'll check the authorisation page, because an htacces solution was already on my todo list, because im using MFP more and more. Also from outside my LAN.
3. I'll check the play function in recent Tv, movies $results = jsonmethodcall("XBMC.Play", '"file":'.escapeshellarg($videoInfo['file']).'"');
4. The new config.php is really nice. Should be in the master!
5. A PHP widget to connect to the Youtube Api for searching video's would be nice! I use greasymonkey to play them remotely on my htpc
We have a national holiday comming up, but im painting my living room. So don't know when i give some feed back, but i'm always into some testing on a user level
1. Yep
4. Just did!
5. Will look into it after v1.0. If you want, create a ticket in mediafrontpage.lighthouseapp.com so we can keep it in our todo list.
niietzshe Wrote:Just a quick example, I have my sickbeard widget on the left showing comingEpisodes. If I click on one I get this error page:
Code:This web page is not available
The web page at [url]http://****:****@localhost:8081/home/displayShow?show=78804[/url] might be temporarily down or it may have moved permanently to a new web address.
*From outside my network. Inside would work I think, maybe not actually, unless I change localhost to the IP of my htpc...
So really what I'm saying is, I need it to look at the htpc's localhost, not the localhost of the computer I'm currently using.
What you should have is http://USER:[email protected]:8081/
Also remember you will have to tell your router which computer it should direct calls to that port (port forwarding). If you have multiple computers in your network then the router would not know which computer is supposed to be called when it is accessed through that port.
You should have most of your links with your DynDNS url. It should work from both internal and external network. Otherwise the entire concept of IP would not work.
_Mikie_ Wrote:I used the merge upstream master and it seems to have worked. My repo should be the same as the master but with authentication added. I updated the new config to work. Please could you check that my if statement for global is correct. Not 100% about that one. Also using your config it says logging out and then takes an age to actually log out. Don't quite know why. Possibly the if (session_id()=='') session_start(); being so low down in the config? I don't know though. Also don't know if the way session start is being used is ideal.
In general please just look over everything and see that its all alright. If anyone wants to test it out
https://github.com/Mikie-Ghost/mediafrontpage
Great! I think you're right. session start is supposed to be one of the first things. Maybe it should be started in the top of the login page? Or maybe the Auth page? Not the config, specially since it is not directly accessed?
