2011-06-06, 03:58
paradoxni Wrote:Currently I do not use xbmc, intead I just run couchpotato, sickbeard, headphones and sabnzb on a my DIY nas.
MediaFrontPage is a great front end for all these, however it looks a bit sparse due to the lack of xbmc.
Currently I use these widgets:
Comingepisodes
Sabnzb
Transmission
Hard drives
Is there anyway to feed in the movies from "wanted" and "downloaded" in Couchpotato? What about a complete list of tv shows i am following from sickbeard? and possibly adding support for headphones (https://github.com/rembo10/headphones)
thanks,
Al.
Headphones looks like a very interesting program! I will also watch it. If you feel the need for more widgets tho, by all means make one and submit it to be added!
SleepyP Wrote:I know Mikie's working on some sort of authentication stuff for MFP as a whole. We should work out the "best" way to integrate that with authentication to the services. For now, I have mine set up so that Apache gives the services it is proxying their usernames / passwords automatically. Until I did that, I found that I would semi-frequently be presented with multiple login prompts, which I find annoying. Aren't there ways to "authenticate" via HTTP headers so that the stuff is working but isn't ever displayed in links?
I'm not sure if you can do that. Would be great if you could tho.
Sleepy, I sent a pull request to your servercheck.php. I feel like you and Mikie should be working together as both of you started adding a ton of checks in different places and they will not be compatible together!
I also noticed you seem to be missing default-layout.php from your repo.
CoinTos Wrote:Well, good news, there is nothing wrong with my regex, just my spelling.
Code:(windows|[b]machintosh[/b]|linux).*\s(.*)\/(.*).*(firefox|safari)\/(.*)/i
[b]should be:[/b]
(windows|[b]macintosh[/b]|linux).*\s(.*)\/(.*).*(firefox|safari)\/(.*)/i
My bad.
Cool, will test it out...
