2011-05-09, 23:55
DejaVu, thank you for your input but I believe you are incorrect on this point. As I posted earlier, I was able to get things working by creating a brand new MySQL database and then populating it using the "stable" 10.1 version of XBMC. The test database was created exactly the same way as the original and was given the same permissions.
Clearly some changes have taken place on the database side during development. The stable builds of XBMC use database version 42, while the nightlies are up to database version 51. This means that if you run the nightly build, it "updates" the database and then it will no longer work with the stable build. I'm gonna ask the devs what else has changed, because this more than likely means the JSONRPC parts of MediaFrontPage may need some tweaks to work on the newer XBMC builds with MySQL.
On a different note, how do you go about adding a widget?
