The webserver you have installed, does it come with PHP? Moreover, what system are you trying to run on? Full blown Ubuntu, XBMCLive?
Try a test.php script to see if it shows.
very nice ..
Only problem it does not work with the XBMC on old xbox
As that one uses the API & not json
Any idea on how to get that working ??
DejaVu77 Wrote:The webserver you have installed, does it come with PHP? Moreover, what system are you trying to run on? Full blown Ubuntu, XBMCLive?
I am installed Xampp for linux 1.7.4 and it shows php is on the list of installed components.
I am running on a full ubuntu 10.04 desktop. I have put a test file and it shows up however when I try to go to the mediafrontpage it just shows a page "The web server software is running but no content has been added, yet"
I dont know if my congifuration file is correct.
My config file
Can you please post a tree of your htdocs folder? Also indicate, which URLs you have entered and what worked.
alshain Wrote:Can you please post a tree of your htdocs folder? Also indicate, which URLs you have entered and what worked.
/opt/lampp/htdocs
I put the test folder with a test.htm and I see file when I go to
http://192.168.1.11/test.
I then put the folder mediafrontpage (renamed) to the same place and go to
http://192.168.1.11/mediafrontpage/
and get a message sayings
It works!
This is the default web page for this server.
The web server software is running but no content has been added, yet.
however how do I get my widgets to show and get all the options like sickbeard, couch potato, etc.. to show? Here is my config file.
http://pastebin.com/NKiWSjUQ
What happens when you go to mediafrontpage/index.php instead?
Also, try replacing your test.html with a test.php with the following content:
alshain Wrote:What happens when you go to mediafrontpage/index.php instead?
when I go to
http://192.168.1.11/mediafrontpage/index.php I get the below
Quote:Warning: require_once(m/mobile_device_detect.php) [function.require-once]: failed to open stream: Permission denied in /opt/lampp/htdocs/mediafrontpage/index.php on line 3
Fatal error: require_once() [function.require]: Failed opening required 'm/mobile_device_detect.php' (include_path='.:/opt/lampp/lib/php') in /opt/lampp/htdocs/mediafrontpage/index.php on line 3
I then put a test1 folder and added a test1.php file inside. I go to
http://192.168.1.11/test1/ and can see an indexpage with the file
my index.php page is as per below
<?php
// Redirect if on a mobile browser
require_once "m/mobile_device_detect.php";
if( mobile_device_detect(true,true,true,true,true,true,true,false,false) ) {
header('Location: m/');
exit();
<html>
<head>
<title>Media Center</title>
<link rel="shortcut icon" href="favicon.ico" />
<META NAME="ROBOTS" CONTENT="NOINDEX, NOFOLLOW">
</head>
<frameset rows='38, *' frameborder=0 border=0 framespacing=0>
<frame src=nav.php name=nav noresize scrolling='no'>
<frame src=mediafrontpage.php name=main noresize>
</frameset>
<noframes>
<p>Your browser does not support frames</p>
</noframes>
</html>
rflores2323 Wrote:Warning: require_once(m/mobile_device_detect.php) [function.require-once]: failed to open stream: Permission denied in /opt/lampp/htdocs/mediafrontpage/index.php on line 3
That is pretty self explanatory, no?
rflores2323 Wrote:I then put a test1 folder and added a test1.php file inside. I go to http://192.168.1.11/test1/ and can see an indexpage with the file
I don't know why you'd go to that page and not to test1.php directly... but anyway, the above error shows, that PHP is working.
FInally got it working.. thanks Alshain for the help
Hello,
I am going to work on getting this installed tonight. I have a couple questions that I hope someone can answer. I have read through most of the thread and was not clear on the following:
I install this on my server pc running windows 7. If I install this on my server pc, I can access the main screen of this application from any other computer on my network? Is this correct?
I am sure I will have more questions later. One more though...I know nothing about PHP, JSON or programming in general. Does anyone know if it is possible to make a widget that allows control of FlexRaid?
http://www.openegg.org/forums/posts/list/6.page
This link seems to be the one that tells how to create a client for FlexRaid.
Thanks,
Mark
Yes, you can access it from other computers.
ok i think i found something weird. in the last couple of weeks i noticed that my xbmc would crash randomly. so i compiled the latest git source and was carefully watching if it would happen again. and i think i found out why. everytime i access MFP which requests info through json my xbmc would crash.
so i went into the config.php to disable the json config.
it did not happen since that, i will be monitoring it further.
anyone else experiencing issues like that?
it did not happen before i had MFP running...
What would help xbmc developers is if you could find if it is a specific json call which is crashing xbmc. For instance when you browse a specific movie or something.
In any case, it is a problem with xbmc not mfp and the xbmc developers have stated that xbmc should be able to handle any json calls (correct or erroneous)
how can i debug the json calls? or where does it go to?
i don't see any json calls in the xbmc.log
